ISY Troubleshooting Flowchart
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 marksanctuary
marksanctuary
    Advanced
  • Members
  • 1,380 posts
Posted 31 August 2010 - 07:36 AM
This is a drop-thru flowchart so after you complete each line-item drop down to the next item until you have resolution of your issues at which point you do not need to continue further down the flow.
Troubleshooting Flowchart Wiki Version - In the wiki version of the flowchart you will also find embedded links for many of the different topics, which may help in parts of this flow that many may be unfamiliar with. Please check it out if you need more detail.
Step 1: Programming not acting as expected?
[*:jt794lqn]Check PLM is powered up
[*:jt794lqn]Check ISY is powered up
[*:jt794lqn]Check for locked up INSTEON devices
[*:jt794lqn]Check ISY error lights
[*:jt794lqn]Flashing "Error" LED = file system issue
[*:jt794lqn]Flashing "Error + Memory" LEDs = IP network issue
[*:jt794lqn]Steady "Rx" LED = ISY-to-PLM communication issue[/list]Step 2: Can you access the ISY main screen?
[*:jt794lqn]Check local IP network issues
[*:jt794lqn]Power down the ISY, local router, and internet modem
[*:jt794lqn]Power up the internet modem, wait until connected to web
[*:jt794lqn]Power up the local router, wait until startup routine is complete
[*:jt794lqn]Power up the ISY, wait until startup routine is complete
[*:jt794lqn]Login to your router, check for IP conflicts[*:jt794lqn]Check remote access (if its part of your current issue)
[*:jt794lqn]Check your dynamic forwarding is correct
[*:jt794lqn]If using UPnP, consider switching to manual port forwarding
[*:jt794lqn]If using a portal service (check-it.ca), check/test that it's working[*:jt794lqn]Try different login methods
[*:jt794lqn]Network places ISY icon
[*:jt794lqn]Local ISY IP (ie. 192.168.1.105)
[*:jt794lqn]UDI web link (ISY-26, ISY-99i)
[*:jt794lqn]Your personal ISY web address[*:jt794lqn]Try different ISY shell login methods
[*:jt794lqn]Telnet to the ISY, run configure TCP/IP, check for network issues
[*:jt794lqn]Connect with a null modem cable
Login with Hyperterminal, 115200, 8, none, 1, none
Power cycle ISY, analyze startup output for issues[*:jt794lqn]Check for PLM issues
[*:jt794lqn]Check PLM cable and RJ45 jack pins
[*:jt794lqn]Power cycle ISY and PLM
[*:jt794lqn]Watch ISY TX/RX LEDs and PLM LED
First bootup flashing, then slow query blinks, then steady when done[*:jt794lqn]Failed result may mean one or more of these possible issues...
[*:jt794lqn]ISY-to-PLM cable is bad, replace with standard network cable
[*:jt794lqn]PLM is bad, work with supplier (ie. Smarthome, etc.) on replacement
[*:jt794lqn]ISY circuitry is damaged, work with UDI on replacement
[*:jt794lqn]Router is configured wrong or damaged, check configuration or replace router[/list]Step 3: From the ISY main screen, can you login to the Admin?
[*:jt794lqn]Clear Java cache
[*:jt794lqn]Install latest version of Java
[*:jt794lqn]Check for firewall issuesStep 4: In the Admin, is there any device communication errors?
[*:jt794lqn]Check offending INSTEON device(s)
[*:jt794lqn]ISY "Query Device"
[*:jt794lqn]Power cycle offending INSTEON device, ISY query again[*:jt794lqn]Check ISY links and scenes
[*:jt794lqn]Check ISY logs
[*:jt794lqn]Run the ISY "Show PLM Links Table", compare output with the ISY
[*:jt794lqn]Run the ISY "Scene Check", analyze for issues
[*:jt794lqn]Run the ISY "Event Viewer" over time, analyze for issues[*:jt794lqn]Troubleshoot INSTEON communication issues, fix signal suckers
[*:jt794lqn]Test AccessPoints, relocate if necessary
[*:jt794lqn]Disconnect electronics and computers
Optional: utility fans, low voltage puck lights, some ballast lighting types
[*:jt794lqn]Reconnect one at a time and test communication issues
[*:jt794lqn]Pick different location or use noise filter for offending signal sucker[*:jt794lqn]Reprogram offending device(s)
[*:jt794lqn]Test device, does it work, status LED off
[*:jt794lqn]Factory reset INSTEON device
[*:jt794lqn]Test device, does it work, status LED still off, possible malfunctioning device
[*:jt794lqn]If device now works, ISY "Restore Device"[*:jt794lqn]Failed result may mean malfunctioning INSTEON device(s)
[*:jt794lqn]Work with supplier (ie. Smarthome, etc.) on replacement[/list]Step 5: In the Admin, can you get to the programs?
[*:jt794lqn]Check for PLM lockup or corruption issues
[*:jt794lqn]Power cycle PLM
[*:jt794lqn]Run ISY PLM info/status check
[*:jt794lqn]If the status is "Not connected", Factory reset PLM
[*:jt794lqn]ISY Restore Modem[*:jt794lqn]Check ISY for file system issues
[*:jt794lqn]Check ISY for flashing "error" LED
[*:jt794lqn]Restore ISY from backup (1st attempt)[*:jt794lqn]Failed result may mean SD card formatting issues
[*:jt794lqn]Format the SD card from the ISY shell
If unable to access through ISY shell then FAT format it on a Mac/PC
[*:jt794lqn]Restore ISY from backup (2nd attempt)[*:jt794lqn]Failed result may mean bad SD card
[*:jt794lqn]Replace SD card, work with UDI on replacement[/list]Step 6: In the Admin, do timestamps exist for program execution?
[*:jt794lqn]Are the programs enabled
[*:jt794lqn]Check ISY logs for signs of execution
[*:jt794lqn]Is the program code broken (ie. devices)
[*:jt794lqn]Program syntax/logic issuesNotes
In order to do a factory reset on INSTEON devices, most types of them require a 10 second removal of power, then holding the set button for 5 to 10 seconds as power is restored.
If you have Windows7 Hyperterminal can be downloaded here.
#2 marksanctuary
marksanctuary
    Advanced
  • Members
  • 1,380 posts
Posted 31 August 2010 - 09:38 AM
All ISY Users,
I think its a good idea that we should work on putting together a complete flowchart that will improve the process of troubleshooting issues with the ISY product line. I am requesting help in this area and am hoping everyone can help me with achieving this goal. If you have a good troubleshooting process please post it in this thread. Also if there is good links in the Forum/Wiki that will help in composing this please also post them here.
Please lets keep this thread only to discussing the improvement of this flow. If you have a troubleshooting issue please search the forum for an existing thread or start a new one. There are many friendly people on the fourm ready to jump in and help!
The ISY root function is to control the switches with programming so I think the major steps should first handle is: if the programmed functionality has gone away, do this. Then the flow walks all the way through to the end point where the program is executing and is leaving a time stamp result.
#3 marksanctuary
marksanctuary
    Advanced
  • Members
  • 1,380 posts
Posted 31 August 2010 - 02:06 PM
I went ahead and stickied it for now.
#4 Michel Kohanim
Michel Kohanim
    Site Admin
  • Administrators
  • 1,210 posts
Posted 31 August 2010 - 09:45 PM
Hi Mark, this is excellent. Would you be kind enough to also add it to the Wiki?
UDI Tech Support
Universal Devices Inc.
Information (Wiki):     http://wiki.universal-devices.com
Submit a Ticket:        http://www.universal-devices.com/contact-support
Email:                      support@universal-devices.com
Phone:                    818.631.0333
#5 marksanctuary
marksanctuary
    Advanced
  • Members
  • 1,380 posts
Posted 01 September 2010 - 08:39 AM
Will do! I am finishing up the last steps then I will make a copy of it in the Wiki.
Thanks Michel!
#6 marksanctuary
marksanctuary
    Advanced
  • Members
  • 1,380 posts
Posted 07 September 2010 - 03:24 PM
Michel,
When you have a moment can you review the process I have outlined above and give feedback on things that don't make since. I am near completion and am ready to work further on the Wiki version of it.
Mark
#7 Michel Kohanim
Michel Kohanim
    Site Admin
  • Administrators
  • 1,210 posts
Posted 07 September 2010 - 09:30 PM
Hi Mark, this is excellent and accurate.
Thanks so very much.
UDI Tech Support
Phone:                    818.631.0333
#8 hjkghj33
hjkghj33
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 20 September 2011 - 12:35 AM
Thanks for taking the time to share this, I feel strongly about it and love reading more on this topic. If possible, as you gain expertise, would you mind updating your blog with more information? It is extremely helpful for me.
saving on energy
