forum.universal-devices.com
Welcome to UDI Forum
It is currently Fri Apr 25, 2014 12:33 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Mon Oct 29, 2012 5:40 am
Offline
I have two motion sensors, and they are set up to send my cell a text message if they detect motion between certain programmed hours.
This works great, but as you can imagine, there are days where I need to be home and such, and the texts get annoying very very quickly.
I'm curious as to how others have solved this. I obviously don't want a physical control sitting around that you can press a button and set a flag on the ISY to disable the motion program.
I can create a program in the ISY that I trigger from MobileLync. But then I need to remember to reset it for the next day. Any suggestions?
Top
 Profile
PostPosted: Mon Oct 29, 2012 6:09 am
Offline
Advanced
Hi Ryan0751-
How about a program that you call from Mobilinc to disable the motion programs and another program that runs every morning to enable the motion programs. Doesn't matter if they are already enabled and this way you don't have to remember.
-Xathros
_________________
ISY-994i Pro v4.2.1
MAC OS X 10.9.2
MobilincPro/HD
DD-WRT x86 V24 Sp-1
CAI Web Control
RaspberryPi/Raspian 7.2
http://xathros.com
Top
 Profile
PostPosted: Mon Oct 29, 2012 8:13 am
Offline
Intermediate
Hi Ryan 0751,
I use DSCLinc software to monitor my DSC alarm system and set a home/away variable. This enables some programs to run and disables others. Alternatively, if you don't have an alarm, you can set a KPL button to enable or disable your motion sensor notifications through a variable. If I used this method, I would probably forget to re-enable the notifications so I would need another program to re-enable manually after some period of time.
Good Luck
Greg
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
