forum.universal-devices.com
Welcome to UDI Forum
It is currently Mon Apr 21, 2014 12:19 am
Post new topic Reply to topic  [ 15 posts ]
Author Message
PostPosted: Fri Jan 17, 2014 7:40 am
Offline
Hi there,
A couple of days ago I noticed that my scheduled ISY routines were not running i.e., lights were not going on and off. So I rebooted the ISY controller at which point the scheduler started working again.
However, since then I can no longer log into the Java admin console, i.e., http://ip address/admin
Here is the build information on my device:
ISY
Model: ISY 99i 256
Platform: ISY-C-99
Version: 3.3.10
Build Timestamp: 2013-01-17-01:38:06
Note I am running of OS X
Java 7 update 51
I am going to try and include some screen shots. Basically I get to the "Please keep This Window Open!" screen.
At this point I was told that I was missing the plugin. This is strange as I have been logging in for years now.
So I downloaded the latest Java plugin (Java 7 Update 51).
Now I get to the same screen but now I am seeing an "Error, click for details" error message.
Clicking reveals the following: "Missing required Permissions manifest attribute in main.jar: http://ip address/web/insteon.jar"
I am hoping that someone can help out as I am dead in the water at this point i.e., no admin access to my system.
thanks,
-reagan
File comment: shot of security exception error message
File comment: shot of login screen with error
Top
 Profile
PostPosted: Fri Jan 17, 2014 8:24 am
Offline
I'm having this same issue but it only started after I upgraded to version 7, build 51.
Top
 Profile
PostPosted: Fri Jan 17, 2014 11:05 am
Offline
jbferg wrote:
would like to ask for some help. I'm having this same issue but it only started after I upgraded to version 7, build 51. I know there is someone here who may know the answer.
Same happened to me. Anyone else have this issue due to a different reason?
Top
 Profile
PostPosted: Fri Jan 17, 2014 2:34 pm
Offline
Me too. After Java update on Win7.
Top
 Profile
PostPosted: Fri Jan 17, 2014 5:07 pm
Offline
Advanced
Hello everyone,
I am so very sorry. You have two choices:
1. Upgrade to 4.1.2 (viewtopic.php?f=25&t=13338) OR
2. Use http://isy.universal-devices.com/994i/4.1.2/admin.jnlp ß do this first
_________________
Michel Kohanim
Universal Devices, Inc.
UDI Wiki
Submit a ticket
Top
 Profile
PostPosted: Sat Jan 18, 2014 9:46 am
Offline
Hi Michel,
Thanks for the response.
I am running an ISY99i and cannot seem to upgrade to 4.x.
Any suggestions as to what I can do to keep my Hardware going. I would hate to think that my HW is obsolete.
thanks,
-reagan
Top
 Profile
PostPosted: Sat Jan 18, 2014 10:11 am
Offline
Advanced
Not sure obsolete is right word but 3.3.10 is the last firmware that can be installed on a 99i. Images after that are too large for the memory in a 99i.
Top
 Profile
PostPosted: Sat Jan 18, 2014 3:13 pm
Offline
New
I had the same problem after going to Version 7 Build 51 today (Jan 18,2014). Error had something to do with security permissions. I went to the Control Panel | Java settings, then to Security tab. Then I added my ISY's IP Address and port number (e.g., http://10.1.1.8:8335) to the exception list and that fixed the issue.
r-
Tom C.
http://www.outcropacres.com
Top
 Profile
PostPosted: Sat Jan 18, 2014 7:11 pm
Offline
Advanced
Just add the URL to your ISY to the Java Exception Site List. No upgrades or anything else is required.
Top
 Profile
PostPosted: Sun Jan 19, 2014 8:51 am
Offline
Thanks for the information on adding my ISY address to the Java exception list. This did the trick for me, I now have access to my ISY99i admin console with the latest Java update installed on my Mac.
this ticket can be closed.
cheers,
-reagan
Top
 Profile
PostPosted: Sun Jan 19, 2014 2:07 pm
Offline
Michel Kohanim wrote:
Hello everyone,
Top
 Profile
PostPosted: Sun Jan 19, 2014 2:18 pm
Offline
Hi,
I just performed the "recommended" Java upgrade and now have the "missing required permissions manifest..." error. Of the 2 choices you propose, I assume I can't try option 1 as my controller is an ISY-99IR-Pro. The other options works in the sense that I can get to my admin console. However, if I try to open the admin console from within the Universal Devices UI, I keep getting the same error. Is there a way for me to continue launching the admin console via the "Admin console" button in the Universal Devices UI?
By the way, I was under the impression that the 99 was higher end than the 994. If 994 is better, what's involved in upgrading to it? Will all my current programs carry over? Are both controllers fully compatible?
Many thanks!
Top
 Profile
PostPosted: Sun Jan 26, 2014 1:35 pm
Offline
I encountered the same error condition after updating Java for Chrome on 1/26/2014. Solved the problem by adding my ISY994i URL to the Java Exception List. But I couldn't find the exception list when I went into Java from Control Panel. The following procedure worked for me:
Start/All Programs/Java/Configure Java
- Click on the Security tab
- Under Exception Site List, see if your ISY99x URL is in the list.
- If not, click "Edit Site List"
- Click "Add"
- Enter your URL in the format "http://[IP Address]:[Port number]"
- Then "OK" out of each dialogue box
Of course, I then got all the requisite warnings the I should not trust the URL (Do you have your mother's permission to do this? :D ) but, since it's MY UL, I told Java it's OK.
Top
 Profile
PostPosted: Thu Jan 30, 2014 1:06 pm
Offline
Advanced
r-
Tom C.
Thanks Tom C. I used this to solve my same problem!
Top
 Profile
PostPosted: Thu Jan 30, 2014 1:32 pm
Offline
Advanced
The 994i is the replacement for the 99i.
The firmware for the 99i had to be frozen at 3.3.10 due to memory space.
So latest Insteon modules needing a later firmware. Will not work with a 99i.
There is an upgrade offer on the UDI Sales web page near the bottom of the page.
http://www.universal-devices.com/sales/products/
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
