MASrules
Everything posted by MASrules
  1. I am trying to follow these directions and having a few hiccups and no success. I have never set up a state variable before. I was able to set one up in the ISY admin console ID = 1 Name = Ringdoor Init = 0 State = 1 I then logged into the portal and tried to create an action. I was able to find the variable and set the Event name, Category and Action as above, but the Resource is set at Ringdoor instead of Ringdoorbellactive and address is set at 1 instead of 8. I can't figure out how to change these. I was able to log onto IFTTT and create an applet. The If integration seemed to go as above. The when doing the then section I could not find a "maker", and it seems like this has been replaced with "webhooks". I was able to paste the address generated by the ISY portal, and set the Method to POST and the content type to "application/json" instead of /jsonapplication. I left the body blank. I was unsure what "now select action" means in the instructions above. The applet on IFTTT seems to run, but I am not sure if the info is actually getting to the ISY. I set a few simple programs to see if it would turn on a light, but the program does not seem to run. The applet says it runs every time the bell rings, but the variable does not seem to activate anything in the ISY. Sorry if I am missing something obvious. Any help would be appreciated.
