tcoates
Everything posted by tcoates
  1. Thanks to everyone for your comments. Especially, it sounds like I may not be totally nuts! The program seems like it should work, and in fact does for the back porch and back yard, but not the front of the house. Note that other programs for different lights do work in the front of the house. So, adding the scene, as i indicated, seems to have fixed the problem !! i do not understand why it was necessary, but it is working so i will leave as it is .. Like the rest of you, if i insist in understanding this, i can kiss off too many hours over the next weeks just to prove i can beat the ())#& computer. Thanks again .. really appreciated. if i do figure it out, i will post. Tom
  2. Sorry .. had trouble getting back into the forum .. I posted the program that is supposed to turn lights off in th AM below .. i just got home today, and see that the porch lights are off .. the program "Sunrise off" had the the last line referring to a scene added when i left a couple of days ago. So minus this line, it didn't work .. the "Front Porch" and "Side Patio" stay on all the day and night, the others turned off as they should. Before i f=left town, i added the all these to a scene called "Sunset Lights Off" and executed it as well .. this seems to have worked. Will see tonight / Tomorrow if they come on and go off properly again .. Since the Scene contains lines 1-4 of the THEN statement, the last line is redundant. Remember lines 1-2 work without being in a scene at the same time, 3-4 do not .. when line 5 executes, all lights are out at the end Sunrise OFF - [iD 0004][Parent 0001] If Time is Sunrise + 10 minutes Then Set 'Backyard 17.EC.8C.1' Off Set 'Back Patio 05.77.4E.1' Off Set 'Front porch 0D.61.19.1' Off Set 'Side Patio 40.83.34' Off Set Scene 'Sunset Lights' Off Else - No Actions - (To add one, press 'Action') Just to make sure the over night lights get turned off I apologize for the repetition above .. assuming the above works, i would like to understand why .. some lights have to be in a scene and others do not .. Thanks for your time ...
  3. I have been using my ISY for many years and upgraded to the ISY994i a year to so ago, replaced the PLM less than a year ago. Everything seems to work. in the past 3 months, my 2466s v.2c relay switch and and 2466D v4.1 dimmer will not respond to my program. They are both in the same room and control patio lights (LEDS) . There is a IF THEN clause that turns on several lights at sundown and another that turns them off after sunrise. All of the other lights respond properly to the IF statements ... except the two in the living room. If i select them from the ADMIN CONSOLE, they respond perfectly. They just do not respond if triggered by the timed IF statements ... Anyone have any ideas? i am out .. thanks Tom
  4. am running isy994i(1120) firmware and UI 4.5.4 on a Mac OS 10.11.5 has been running more or less OK for a few years. sometimes flaky, but runs 95% of the time .. recently had problems with program response, could control device directly from the Mac, but the programs that had run before were inconsistent. I replaced the PLM and this seems to help ... I have several Model 2342-2 mini remotes .. they link to the devices and seem to control things OK .. However, i would like to see them on the ADMIN CONSOLE. the old remote 2440 shows though i will not longer program .. I tried the "link a 8 scene remotelinc-2 option from the dropdown and put in the address .. but this doesn't work .. if i put the admin console into linking mode .. and press the set button on the mini, nothing happens ... Any advise? appreciate your time ... tom
