aanthony
  1. aanthony posted a topic in ISY994
    I am on 2.8.10. I have a (load) switchlinc for a kitchen light. I created a scene with that light and a secondary button on a 6-button keypad. They are both setup as controllers. When the KP button is pushed the light goes on and the load switch responds (as expected). However when the load switch is pressed the light goes on but the KP button does not light. This used to work fine. FYI: I restored the KP and all works now.
  2. Can someone explain (to a beginner) the differences for the status of a relay (on/off) and sensor (on/off) Can I assume you could program the I/OLinc so that the sensor is on if the door is closed or off if open. I basically want to open or close the door using a keypad button and have the button show the status (lit if open, unlit if closed).
  3. aanthony replied to aanthony's topic in ISY994
    Michel............ I have some bad links that I can't find. Don't know if they are scenes or programs so I thought a clean start and add them back one at a time would make sense.
  4. aanthony posted a topic in ISY994
    What is the easiest way to remove all links to/from devices and the ISY?
  5. I changed internet carriers and the gateway has switched from 192.168.0.1 to 192.168.1.1. Naturally I cannot login into the 99i and I cannot find the directions on how to telnet into the device to change the IP. Can anyone help?
  6. aanthony replied to aanthony's topic in ISY994
    I had another senior moment.
  7. aanthony posted a topic in ISY994
    I have a lamplinc that is crosslinked in a scene to a secondary button on the KPL. It works fine. How do I get that secondary button to sync up with the lamplinc if it is turned on via IR (remote)?
  8. aanthony posted a topic in ISY994
    I heard a rumor that the new improved Smarthome PLM is now available. One, is that true and Two, what is the model number? Thanks
  9. aanthony posted a topic in ISY994
    Do you anticipate creating a new forum for the 99iR?
  10. Good point.
  11. Is there an easier way than creating 5 folder/programs for the following scenario? SW1 controls a porch light and FL1, FL2 control two different sets of floodlights. I want the following to happen: 1. Daytime(Sunrise to Sunset) -> if SW1 turned on -> wait 1 min and turn off (turned on accidentally). 2. Sunset to 11:00PM -> if SW1 turned on -> turn on porch light, flood1 and flood2 -> wait 20 min -> turn off porch, flood1 and flood2. 3. 11:31PM to Sunrise next -> if SW1 turned on -> turn on porch, flood1 and flood2 -> wait 20 min -> turn off ONLY porch 4. Sunset to 11:30 -> if SW1 turned off -> turn off porch and floods 5. 11:31 to Sunrise next -> if SW1 turned off -> turn off porch only. Thanks in advance
