rudyramirez
  1. Yes they are incandescent, my PLM is in the same room as the plugs for 2 iMacs, but on a different plug on top of a 7ft. cabinet. I do not have a ups. 12 ft away from a couple of Drobo power supplies. I don't have any conditioners or filters, Should I?
  2. Ok, here's where I run into a problem. I had an electrician install all the switchlincs because I will most definately burn the house down if I were to do it. So I can't relocate the devices. I don't know how to determine the load type other than to say they are wall toggles that control several 75watt flood lights. Individually, the switches work as expected, except from within a scene. Hopefully there are other things we can try without removing and/or replacing switches. (unless they are bad)
  3. I double checked Here's what i have: 2 - (2456D3) Lamplinc v.33 3 - (2456S3) Appliancelinc v.32 28 - (2476D) Switchlinc Dimmer v.3.7 4 - (2476S) Switchlinc Relay W/Sense v.37
  4. I plugged it in as you requested and scenes still do not work. I don't understand why I can control all devices from the console and of course by their switches but when they are in scenes, they just don't respond.
  5. I tested the scene and one succeeded and one failed
  6. Yes, they can control each other by pressing either switch. When i click on the scene icon, the levels are: On Level 100 Ramp Rate 2.0s
  7. I suspect this is a simple issue but I'm not able to figure it out. I'm not able to control lights from within a scene. I've created a scene and placed two (2476S)SwitchLinc Relay W/Sense v.37 into the scene as controllers. This is a 3-way switch and i simply want either switch to turn the lights on/off. I can control both from My Lighting list but when i attempt to control either from within the scene... nothing. When i try to control the scene...nothing again. What am i doing wrong? isy99i Mac v.2.7.15
