Ebrune
Everything posted by Ebrune
  1. I unlinked/relinked. Unfortunately I am getting the same results. Eric
  2. Yes, I tried that earlier today as well. It didn't affect anything. The interesting thing is when I ask Google to set my temperature to say 72 degrees GH even replies back "ok, setting the temperature to 72 degrees". Of course it could be saying one thing but doing another. Eric
  3. Still no luck. I'm starting to think I may need to find a workaround. Thanks for your help so far. Eric
  4. Hey Benoit, Alright I asked Google to "sync my devices" and Google acknowledged it will now sync devices for Universal Devices. I then waited a minute or so then asked Google to "Set my thermostat to 71 degrees". Display on thermostat for heat unfortunately changed into Celsius again. Eric
  5. Will do, thanks.
  6. Yes, that's what I thought as well. I did as you said and removed it from ISY Portal and added it again with no luck. After adding it again to ISY Portal I then unlinked/linked to Google Home with no success.
  7. Hello all, Thank you everyone for all of the information. Unfortunately it seems I have a similar issue regarding different UOM. My thermostat is set to 71 and 79 on Program Mode. When I ask Google Home what is the indoor temperature it correctly states the indoor temperature is 70 degrees with a set point of 71 and 79 degrees. So Google Home is reading in the correct unit of measure at this point. When I ask Google home to set the heating temperature to 72 or increase the temperature by 1 degree it replies that it has adjusted the temperature with no problem. When I go to look at the display on the thermostat the heat set point says OF, what I assume is off, and the cool set point is in Celsius reading 26 or 27. I tried removing the device from ISY Portal and re-adding it then unlinking and linking to to Google Home again. But the problem persists. Just seems strange that Google Home is speaking the same language as the thermostat until I change the temperature and things go sideways. I appreciate any thoughts on this one. Thanks a bunch, Eric
