lmalm
  1. Well, in case anyone else runs into this problem... The solution was to change the Alexa Category type from "Scene" to "Light" in the ISY portal. This made all the lights show up as lights instead of scenes in the Alexa app, and now they all work with spokens. This was an easy fix - I just figured they were all "scenes" since they are ISY scenes - not the case. Anyway... Just in case anyone else runs into it, that's the fix.
  2. When I moved from the ISY994i to the "eisy | home r2" I l also moved from MobiLinc to the ISY Home V3 skill. This seemed to work well at first - I started by removing all the MobiLink devices in the Alex app, and then removed the MobiLinc skill. The problem came when I added back spokens into through the ISY portal. If I didn't use the spoken name before, it works fine. But if I try to use the same spoken as before (for example, "Kitchen Lights") Alex tells me I cannot control that device any longer, because the skill has been disabled, and I can re-add the skill to get it to work again. I've ensured that all the previous scenes and devices that were linked to MobiLink have been removed in the Alex app, but this doesn't seem to matter. It's almost like there's a "ghost" entry somewhere for the previous spokens setup through MobiLinc that won't go away, and now the new spokens setup through ISY Home V3 don't work. Has anyone seen this issue or have a solution for it?
