PGHBubba
  1. Not sure if this is an issue local to my system or if Tesla changed their cloud connections. Recently noticed that my Power Walls show "Not Connected" and under usage history the Connected to Tesla shows "offline". It appears to be connected locally as I am getting data on the short poll interval and my Tesla app shows that the ISY is talking as I can see my backup reserve changing daily (due to a program I have running that sets it to my preferred level at 1100). I am using a Polisy running latest versions (IoX 5.9.1, Polyglot PG3x 3.3.21, and udiTeslaPW2 version 0.1.29). Did the usual uninstall/reinstall/update/reboot set of tricks with the node server and Polisy. Tried different slots. Checked my authentication with Tesla and the debug logs shows the token is still valid. Let run a few a days to see if it self healed with no success. Are others having this issue? The node server has been running without issues since last year and this seemingly happened (can't tell when though looking at the logs).
  2. I have similar issues where the Nodeserver lists a message that I need to re-authenticate. Re-authenticating works for about 1/2 a day and then the same message appears. Started occurring July 7th. I also notice that in the Ring.com accounts for Authorized Client Devices my ISY does not show up like it used to.
  3. Different slot. Tried various things: Stopping the old version. Then deleting the old version in case they were stepping on each other. I also lowered my battery level from 100% (we are in active storm watch mode all day due to weather) to see if it needed to change to be reported. No luck. I created a temporary variable to write the battery value to (as kWh) and it would never change (variable stays at 0.0000).
  4. Thanks. I think I will revert back to the old version. I did several experiments and cannot get the powerwall battery value in any program, even set as kWh. It shows up in the nodeserver (GV0) as the correct value as well as the admin console in the main screen and it matches my Tesla app but for whatever reason it is not able to be used in a program.
  5. PGHBubba posted a topic in TeslaPW2
    @Panda88 I just updated to this version of the nodeserver and found that the status condition on Remaining Battery only allows "kWh" or "other" in program conditions whereas the previous version allowed %. There also appears to be a bug when "other" is selected as it only allows "98" or "no data" for the pull down. Any chance the remaining battery can be updated to also allow "%"? The remaining battery value when selected to either Index or kWh also does not report anything in program actions (it is reported on the status screen though).
  6. I installed the Ring Nodeserver but cannot get the motion alerts portion to load in the Administrative console. The doorbell and motion appear as nodes in PG3x and both appear as nodes in the console but under motion the screen is empty. No ability to select the node in any programs as a trigger. Running latest IoX on Polisy and PG3x. I tried the usual uninstall, clear cache and reinstall with the same results. Using the "Test Ring" button results in success. Any ideas?
  7. PGHBubba started following Javi
  8. We are a house divided between Android and iOS and need to have the UD Mobile App work on both. I have successfully created a setup on an Android tablet and been able to use the Backup/Restore function to duplicate my favorites on my Android phone. A problem occurs when I try to use the same backup file on an iPad or iPhone. I get a screen that states the restore is successful and the app needs to restart. Upon restarting the app immediately crashes. Same response on the iPad and an iPhone. The only workaround is to completely uninstall and reinstall the app on the iOS device. My goal is that I want to be able to create a single setup and have it duplicated on either an Android or iOS without going through the lengthy process of creating multiple setups. Is this even possible? If so, how can I use the restore function with the same backup file on multiple platforms?
