milodorr
Everything posted by milodorr
  1. @Panda88, I believe the units for the instantaneous value labels (e.g., Inst Home Load) in the Power Wall Status node should be kW rather than kWh. Hopefully an easy fix. Thanks
  2. In one node (named "Usage History") of the four installed with the udiTeslaPW2 nodeserver, I did indeed find a status value set to a chart. I set it to Default (wish I had paid more attention to which one I changed), and all the "Charted Status" error messages have gone away. For sure, I hadn't been messing with any of those status values previously, since I didn't know they were there until you told me! In any case, thanks for your expert and speedy help.
  3. Sure, here it is. Let me know whatever other info I can provide. Thanks
  4. After syncing UDMobile following the installation of the udiTeslaPW2 nodeserver on my eisy, I am getting flooded with multiple error messages: "Error Charted Status is a beta feature which must be enabled. If this feature was already enabled then the status must change at least once before data is available. See https://wiki.universal-devices.com/UD_Mobile#Status_History Error 503." I went to that site, but I still don't understand how to turn off this beta feature. Where does the line /rest/history/node/properties/recording/off go?
  5. In my case, the program I have to turn on my evening lighting, which is set to run at sunset minus 30 minutes, definitely ran an hour early. I was on my couch watching a football game when the lights came on at 3:30. I then fired up the AC to try to understand why.
  6. Same for me. eisy (v5.8.4 firmware) thinks PST sunrise/sunset is 5:15a/3:57p, which is a bit more than an hour early here in the SF Bay area.
  7. And thank you @rayg for sharing your experience and the extra tips. They helped me get going again too.
  8. I'm now able to log in again too. As @Geddy said, there's a several second "Loading..." delay before being able to access the dashboard. Thanks
  9. Me too. I seem to be able to login (as indicated by a brief message to that effect, as well as the fact that I can faintly see the normal stuff (e.g., correct ISY uuid) behind the spinning "Loading..." message), but I can't get to anything (e.g., dashboard, store), as now reported by others. While the "Loading..." message is being displayed, I periodically get the message "Couldn't update driver to ISY" as well as "connection Failed. Error" messages. From the ISY side, everything looks normal, e.g., my PGC nodeservers (Ring, Ecobee and PurpleAir) still seem to still be running. Yesterday, I saw a variety of non-repeatable behaviors, but it sounds like the system was being worked on. Later in the day, the behavior settled into the current situation.
  10. @JacktheRipper, did you ever find any information about item (6) in your original post in this topic (what do the Polling Interval and Hysteresis fields in the Light section do)? Thanks
