mvgossman
  1. Problem solved thanks to Geddy. I turning on my scene with the administrative console and it didn't work as expected even though it does work via either of the physical switches in that scene. So I removed the scene and re-created it and the admin console now operates it as it should, and running "THEN" with that program operates it correctly. Hope this helps any readers in the future! Thank you very much, Geddy!
  2. I do not understand how a scene can not be set up properly as an ISY controllable device. For this example, the "Cleats Lamp" scene is controlled by a switch and the sole responder is the lamplinc for that lamp. It works fine when triggered by the controlling device, but when putting the scene as a "THEN" in the program it doesn't work. I'm running eisy v.6.0.0 Here's that program: <?xml version="1.0" ?><triggers><d2d><trigger><id>40</id><name>Cleat and Hearth off</name><parent>1</parent><if></if><then><cmd id="DFOF" node="7191"></cmd><cmd id="DOF" node="7191"></cmd></then><else></else><comment></comment></trigger></d2d></triggers>
  3. First off, what's the appropriate forum for programming with the Administrative Console? Anyway... With my ISY994i I had a program triggered (IF) by a button to trigger the program with a number of "THEN"s to turn off multiple scenes. It worked fine, but now it doesn't. How do you put in "THEN" to turn a scene on or off in one fell swoop? I swear it used to work as you'd expect. If there isn't a way, a workaround would be to put in "THEN" every single switch and button in the scene, but that's a painful workaround.
  4. Since I can't use the Admin Console, I can't go into the reset options to determine what I did, but basically it was a last ditch effort to get things to work again via deleting all of the ISY994's data prior to restoring from my last backup. Yes, cleared cache all three boxes and downloaded a fresh copy of start.jnlp. Current version of Java on the Mac. When opened, I have to go into the Mac Privacy and Security settings to allow it to be opened, and still nothing. I've done this a few times, and always worked before, the console appears instantly in both LAN and Cloud options. And like I said, the very strange additional thing is that the login using the Cloud access method doesn't work, as if the password is incorrect, but it just isn't. Is there a way to do a factory reset on the ISY994 and start over? But, I'm willing to get an Eisy anyway, I understand it has some speed, usability, features, memory, and more that make it time to upgrade anyway, do you agree with that?
  5. I had a power surge/failure destroy my serial modem so I replaced it. I know my ISY994i is alive and kicking since I can access it via the ISY Portal's ISY Web Access, operate lights and so on. I have long used the Admin Console on my Mac, but when I use it now (see photo) it doesn't pull the LAN based access to it automatically. I added the Admin Console URL manually on the IoX Launcher, audit shows up as Cloud access, but when the "Authenticate My Lighting" dialog box comes up, my login credentials don't work. I tried the default admin-admin and no go. Certainly didn't change the password, but at any rate I know it's operating inside that black box because it works through the Web Access. I updated Java, cleared all the cache boxes, restarted everything (cable modem, router, serial modem, and the ISY994), and it won't budge. During all this troubleshooting of the failure after the thunderstorm, I misguidedly reset the ISY994's data and thought I might have to restore from a backup, perhaps that is related. This might be an opportunity and excuse to finally start from scratch with an eisy (WITH SUPPORT!), including redoing my entire network of lighting products, but anyway, any thoughts on what's going on?
  6. Thank you, "Geddy", I've been fat dumb and happy for a long time with the system I have. I wasn't aware of the new PLMs, that was a crisis for the unlucky people whose systems were hanging by that crucial device as I recall. I guess I'll go whole hog with the eisy and get a USB PLM. I've got too much invested in Insteon switches to bail on it, nothing I've found has the functionality I want. I'm finding Insteon switches and other things to be pretty easy still on eBay, thankfully.
  7. Thank you, I'm afraid Nodeserver is greek to me, will look into that. Mobillinc does seem rather dated. What is the app on the iPhone called that allows access to the full range of features?
  8. My ISY994 works perfectly, no complaints. The only reason to upgrade to the eisy for me would be for irresistible features, and I suppose better stability and room for growth in the future. Naturally, I'm worried about encountering a major problem and wishing I hadn't undergone the major surgery. SO! 1. Is the interface for programming scenes, devices, etc. still done through the iOx Launcher Admin panel via Java? A nice new feature would be a more robust Admin panel. 2. Is the MobilLinc Pro app still usable? 3. And while I'm at it, is there a way to interface to a different PLM? I've been fortunate, my two PLMSs (two homes) are going strong, but my luck could run out. 4. Any other great features to be gained?
  9. I agree... I was joking about the cost because it's so reasonable.
  10. Thanks! I didn't find anything specific in a search with respect to the VTEXT for Verizon being down, but now that I know it's truly down, and possibly no workaround, I just installed Pushover, and it is great. I suspect I'll find this useful in other situations. I just realized that you can set the Mail app to put up on alert notification whenever an email is received by a certain email address. One could have a special email address only used by the ISY. I'll have to think about this before I put forth that massive cost of $4.99 for lifetime Pushover use. Still, Pushover also integrates with multiple devices very nicely, although I can't get the notification to work yet on the Mac, I've got a support question to Pushover in for that.
  11. I use Gmail to send text messages from the ISY994 to my Verizon cell phone. Not long go, it stopped working, and found out about the Advanced Security issue at Google that required you to set up a unique password to allow an external app (like the ISY's email capability) to use Gmail as the email client, and it started working again. Within the past week, I stopped receiving texts again. I researched it, and supposedly Verizon has stopped passing through to Verizon's "2125551212@vtext.com" email to text feature. It also doesn't work with an email client on a regular computer to send a text to the vtext email address when using Gmail, but when using an alternative email address service (in my case, my office's domain name that uses Microsoft, I receive a text just fine. Is there a workaround to salvage the Gmail method? If not, what's the SMTP configuration for an alternative email address? I only have one other email, a Yahoo address, and I've tried everything and it won't work.
  12. There are some PLMs with the USB interface (2413U) for reasonable prices out there. The ones with the ethernet connection are outrageously expensive. So if the new Polisy Pro works with the USB, maybe this is a good time to upgrade from the ISY994? Or is it a foolish time to upgrade because of the lack of availability of replacement Insteon switches, and especially because of the entire thing hanging on that PLM which isn't being made now? Universal Devices is very straightforward about this risk, pointing out that they are not available and accepting requests for one that they'll provide when they have a source for them. Or does the Polisy provide an interface between Insteon and other networkable switches that will fill in the gaps smoothly? By "smoothly", I mean is there another brand of switch and alternative technology, with ready availability, that will instantly participate in a Scene with Insteon switches?
  13. I confess I hadn't heard of Polisy, will check it out.
  14. Thanks for that UD Mobile reference, looks interesting. Is there a way to use the USB version of the PLM with the ISY994i?
  15. Where does one access these? Are they manufactured in another facility??
