Hawkspoint
Everything posted by Hawkspoint
  1. Hawkspoint posted a topic in eisy
    Has anyone heard of Shelly devices? They seem to work, but there is no integration with EISY or Poliglut
  2. Hi, thanks for your answer.
  3. here is the newest error
  4. purchased the node; installed it; restarted everything several times; was charged twice for the node; opened node server configure (01)Kasa (network) with anything I can imagine; uncertain about UserID (which); host name (which host); restarted again; nothing; pulled the power plug on the Eisy; nothing; this is very frustrating; I have one old cheep plug, 2 new KP125MP2 and a tapo Smart Hub with chime
  5. Hi, I removed and re-installed the Eisy; re-installed the Kasa plugin; it finds itself, but no other devices. The one device it finds does not work; it does not even have any on off or other links. Can you help me?
  6. Thanks for answering so quickly; there only one installed, but I cannot tell which one. It says [03] Kasa (Network)
  7. Hi I cannot add any plugs. I have the trial version AND the paid installed. How can I remove the trial? Thanks Hermann
  8. the 1101s showed up after a restart; I had to go to all wireless devices and push/hold to write changes one at a time; took 2 hours
  9. Thanks I have no 1101 and no scenes
  10. Thanks, firmware is 5.3.3 so is the UI
  11. Hi Using Pro; I have several sensors in multiple locations. It is impractical to go around and put them all in com mode every time I make a change to one of them. When I make a change to one, that is the only one that needs to be updated! Right?
  12. Every time I make any changes to any of the devices like sensors, the system takes a very long time (20 Minutes or more) to initialize. In the middle of things it says System Busy, and it tries to initialize all sensors instead of just the one I tried to add or change. Is this screw up in version 5? Can I go back to something that works? Thanks for any hints. Hermann
