Matt M
  1. For what it's worth, mine are both 2450 IOLinc v41. I have an Isy994I/IR Pro running v.4.9.0.
  2. First I would like to thank everyone for their replies. I apologize for taking so long to get back to this, but I was having issues with programs that I was trying to work out. I see that I could combine two of the programs, but I believe that the "Night Close" program needs to be separate because of the If statement to see if the door is still up 10 minutes later. From the ISY cookbook: "• To break a Repeat sequence, add a "Repeat 1 times". Actions after this Repeat will only run once (that is to say, they won't repeat at all). This is useful when you want some Actions repeated, but then want to continue on with more Actions that should not be repeated." I have two garage doors, and also have two keypad buttons that light up to indicate that the respective door is open/closed. They can also be used to open/close each door. This leads to why it took me so long to reply to this topic. I have the garage lights come on when either door is opened, and turn off two minutes after both doors are closed IF the garage lights weren't turned on previously. I was having consistency issues when using the standard method of monitoring the switch and sensor. I came up with the following programs that monitor the two keypad buttons that open/close the garage doors instead, and this has been reliable for me. Now that I have confidence in being able to read the status of the garage doors consistently, I am comfortable in moving forward with the auto-closing of the doors.
  3. I know that there have been other programs posted regarding automatically closing garage doors at night. I have also run across the many warnings to heed before proceeding. This is my attempt at programming the task myself. The rules are as follows: 1. Only close the door between 9pm and 6am. 2. Only close the door if it has been open for 10 minutes just in case we come in at between those two times. 3. Flash the garage lights as a warning, and then close the garage door. Do my programs look correct to accomplish this task?
  4. You are correct, I removed the scene, and the device continues to report status as it should.
  5. Following up on this: I added the device to a scene all by itself, made no other changes, and now the status is reporting correctly. This makes no sense to me, but hopefully it will to you guys. It's working, so I'm happy. ?
  6. I did post these in my first post, but I did it again and there are still no mismatched links.
  7. No change, still not updating status.
  8. Manually turning the switch on and off does not report status, however turning it on and off from the admin console does. I can't turn the switch on from the admin console, but fast on, fast off, and off do work. I tried this by unscrewing the bulbs, and it did not make a difference. I appreciate your responses, and am hoping that you will be able to help me get this working.
  9. 2477D Dual Band SwitchLinc Dimmer v.45 Lighting load with 110v LED bulbs
  10. Fri 12/31/2021 03:49:14 PM : [ 4D B1 75 1] DOF 0 Fri 12/31/2021 03:49:18 PM : [ 4D B1 75 1] DON 0 Fri 12/31/2021 03:49:28 PM : [ 38 A6 8D 1] DON 0 Fri 12/31/2021 03:49:28 PM : [ 38 A6 8D 1] ST 255 Fri 12/31/2021 03:49:33 PM : [ 38 A6 8D 1] DOF 0 Fri 12/31/2021 03:49:33 PM : [ 38 A6 8D 1] ST 0 I was originally having issues with device 38 A6 8D not showing status in the event log. I physically replaced that device with a new device 4D B1 75, and then did a "Replace Device". It still wasn't reporting status, So I performed a "Restore Device", and eventually I deleted and added the device, but still but the new device is still not sending status. I installed the original device in a location that is literally less than 4' from it's original location, and it is now sending status updates. The device is located in the master bath in a double-gang box with another insteon device, and within a 9' radius of 10 other devices. I have 26 Switchlincs, and 17 Keypadlincs, and I am not having any issues with any other devices. I just can't see this being an issue with the physical location of the device, but I am at a loss as to what else it could be. PLM Version 9E
