dblee1950
  1. thanks for trying. i'm in touch with them but probably won't get anything till monday.
  2. here's what popped up. I have no idea what it means isy not running? (check /var/isy/isy_svc.pid). isy service failed since no process with id 12718 exists ... Fixing permissions for ISY scripts Checking to see whether or not we need to migrate from 994 ... Setting permissions for ISY directories/files you can disable uftdi driver by adding isy_load_uftdi=NO in /etc/rc.conf 7 1 0xffffffff828b4000 83a0 uftdi.ko isy: 1763156932 -> 0 Starting isy.
  3. Just did. It asks for password
  4. Yes I'm sure. The router identifies it as the eisy and the IP is the same as it was before this started. The router shows it connected. The MAC is right too
  5. I got a notice that eisy went offline yesterday morning. I've tried rebooting, checking cables, etc. I can ping it and it shows on my router as active, but admin panel, app say it's offline. What else can I do to resolve? Yes, I have started a ticket but haven't heard anything since yesterday. My firmware is out of date, but I don't know how to update since I can't get online with it. Any help appreciated.
  6. I'm getting temp and lux readings, but when I try to do a query I get request failed error. I get it on all the nodes. Is that just the way it works or is there a setting I need to make? thanks
  7. UPDATE: I removed it and reinstalled and now see the other nodes.
  8. I'm using an EISY with ioX v.5.8.0
  9. I have installed the UD USB Dongle and am attempting to get the TriSensor up and running. On my AC, it shows ZY 002 V1 Alarm and ZY 002 Wake Up. Light on sensor shows it is included FWIW. How to I get light and temperature readings from this?
  10. It seems every time I'm away from computer for a period of time and come back to PC I have to close the console out and restart. Is there a setting or a way to keep the console open and functional until I shut it down?
  11. I want to just add a simple lux measuring capability to my eisy setup to control light programs. Will this work with eisy? Aeotec Z-Stick 7 Plus Aeotec ZWA005-C TriSensor Z-Wave Plus S2 I have no experience with Z-wave or Zigbee so am approaching this cautiously. I don't see the need for me to use the more expensive UD dongle, but would like your thoughts. thanks
  12. dblee1950 replied to dblee1950's topic in ratgdo
    UPDATE; Success, sometimes the simplest solution is right in front of me. Went through every page of isy portal site and under my profile there it was. I have two isys, a 994 and the newer easy, although I don’t have 994 online anymore. The 994 was set to use preferred isy. Once I changed it Alexa found the opener and light right away. Thanks for all the input😀
  13. dblee1950 replied to dblee1950's topic in ratgdo
    Here are a couple of screenshots. I'm using ISY Optimized for Smart Home V3 in Alexa to connect between the two. All looks ok until I try to have Alexa discover the ratgdo. She finds other devices but not the ratgdo.
  14. dblee1950 replied to dblee1950's topic in ratgdo
    I'm running ratgdo plugin as a node on eisy. Garage door shows up as ratgdo on admin panel along with ratgdo light. It also shows up on the polyglot page under ratgdo as two nodes, garage door opener and light. I have Amazon echo device list setup as ratgdo device device\open-close n006_ratgdo garage and spoken as garage door. But when I ask Alexa to discover devices, it doesn't find ratgdo. If I ask alexa to open garage door, it says, sorry i didn't find a group or device named garage door, guess since it didn't discover ratgdo. frustrating
  15. dblee1950 replied to dblee1950's topic in ratgdo
    Yes I found that and set up a spoken, but Alexa doesn't find ratgdo and there is no skill for it to. I tried telling Alexa to open the garage door as I set up in spoken, and she says sorry I didn't find a ... named garage door. I don' t get how Alexa triggers a program in EISY with no device link. I did create a program in EISY to open garage door. I tried scene also with same results. What am I missing if this is doable?
