dblee1950
Everything posted by dblee1950
  1. thanks for trying. i'm in touch with them but probably won't get anything till monday.
  2. here's what popped up. I have no idea what it means isy not running? (check /var/isy/isy_svc.pid). isy service failed since no process with id 12718 exists ... Fixing permissions for ISY scripts Checking to see whether or not we need to migrate from 994 ... Setting permissions for ISY directories/files you can disable uftdi driver by adding isy_load_uftdi=NO in /etc/rc.conf 7 1 0xffffffff828b4000 83a0 uftdi.ko isy: 1763156932 -> 0 Starting isy.
  3. Just did. It asks for password
  4. Yes I'm sure. The router identifies it as the eisy and the IP is the same as it was before this started. The router shows it connected. The MAC is right too
  5. I got a notice that eisy went offline yesterday morning. I've tried rebooting, checking cables, etc. I can ping it and it shows on my router as active, but admin panel, app say it's offline. What else can I do to resolve? Yes, I have started a ticket but haven't heard anything since yesterday. My firmware is out of date, but I don't know how to update since I can't get online with it. Any help appreciated.
  6. I'm getting temp and lux readings, but when I try to do a query I get request failed error. I get it on all the nodes. Is that just the way it works or is there a setting I need to make? thanks
  7. UPDATE: I removed it and reinstalled and now see the other nodes.
  8. I'm using an EISY with ioX v.5.8.0
  9. I have installed the UD USB Dongle and am attempting to get the TriSensor up and running. On my AC, it shows ZY 002 V1 Alarm and ZY 002 Wake Up. Light on sensor shows it is included FWIW. How to I get light and temperature readings from this?
  10. It seems every time I'm away from computer for a period of time and come back to PC I have to close the console out and restart. Is there a setting or a way to keep the console open and functional until I shut it down?
  11. I want to just add a simple lux measuring capability to my eisy setup to control light programs. Will this work with eisy? Aeotec Z-Stick 7 Plus Aeotec ZWA005-C TriSensor Z-Wave Plus S2 I have no experience with Z-wave or Zigbee so am approaching this cautiously. I don't see the need for me to use the more expensive UD dongle, but would like your thoughts. thanks
  12. dblee1950 replied to dblee1950's topic in ratgdo
    UPDATE; Success, sometimes the simplest solution is right in front of me. Went through every page of isy portal site and under my profile there it was. I have two isys, a 994 and the newer easy, although I don’t have 994 online anymore. The 994 was set to use preferred isy. Once I changed it Alexa found the opener and light right away. Thanks for all the input😀
  13. dblee1950 replied to dblee1950's topic in ratgdo
    Here are a couple of screenshots. I'm using ISY Optimized for Smart Home V3 in Alexa to connect between the two. All looks ok until I try to have Alexa discover the ratgdo. She finds other devices but not the ratgdo.
  14. dblee1950 replied to dblee1950's topic in ratgdo
    I'm running ratgdo plugin as a node on eisy. Garage door shows up as ratgdo on admin panel along with ratgdo light. It also shows up on the polyglot page under ratgdo as two nodes, garage door opener and light. I have Amazon echo device list setup as ratgdo device device\open-close n006_ratgdo garage and spoken as garage door. But when I ask Alexa to discover devices, it doesn't find ratgdo. If I ask alexa to open garage door, it says, sorry i didn't find a group or device named garage door, guess since it didn't discover ratgdo. frustrating
  15. dblee1950 replied to dblee1950's topic in ratgdo
    Yes I found that and set up a spoken, but Alexa doesn't find ratgdo and there is no skill for it to. I tried telling Alexa to open the garage door as I set up in spoken, and she says sorry I didn't find a ... named garage door. I don' t get how Alexa triggers a program in EISY with no device link. I did create a program in EISY to open garage door. I tried scene also with same results. What am I missing if this is doable?
  16. dblee1950 posted a topic in ratgdo
    Is there a way to use the ratgdo with Alexa? There doesn't seem to be a ratgdo skill. thanks
  17. OK, got connected but it doesn't find my devices. Just starting with TP-link, this is a couple of smartplugs, EP25P4. Log says: 2023-12-29 10:13:19,184 Thread-12 kasa.discover DEBUG discover:datagram_received: [DISCOVERY] Unsupported device found at 192.168.0.164 << {'result': {'mac': '48:22:54:A2:5F:40', 'tmp_port': [20001], 'hardware_version': '1.2', 'group_name': 'UHJpZGVfQmx1ZmY=', 'need_account_digest': True, 'owner': 'ad7e01492048820889f788af8a048f0b', 'master_device_id': 'cd38fde4457325ab88372467a44194ef', 'ip': '192.168.0.164', 'device_type': 'HOMEWIFISYSTEM', 'role': 'master', 'channel_2g': '4', 'device_model': 'X55', 'device_id': 'cd38fde4457325ab88372467a44194ef', 'group_id': '67f4dcb8697afc57459b1657a28f744f', 'channel_5g': '48', 'factory_default': False}, 'error_code': 0} Does this mean that the smarplugs cannot be used with eisy at this time? I have some switches coming in in a day or two that are new. Will this only work with older devices? thanks
  18. Thanks, Brian. This was very helpful
  19. I have version 3.1.4 and version 5.7.1 of the iox and version 3.2.16 of the PG3. I don't see dates on my dashboard other than time started. I don't know what or how to update modules/install dev packages. I see nothing that says update in the PG3 store for kasa
  20. Having issues too. Kasa never seems to connect. On admin panel it shows the node server and lists several smart devices, but kasa doesn't show up on left side of panel under Network. I tried removing kasa from pg3 and eisy and reinstalling with same results. Log shows it trying to do something over and over. Here's a section where there is an error: 2023-12-28 11:23:05,457 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): File "/var/polyglot/pg3/ns/0021b9026925_4/kasa-poly.py", line 12, in <module> from nodes import VERSION,Controller File "/var/polyglot/pg3/ns/0021b9026925_4/nodes/__init__.py", line 9, in <module> from .SmartDeviceNode import SmartDeviceNode File "/var/polyglot/pg3/ns/0021b9026925_4/nodes/SmartDeviceNode.py", line 8, in <module> from kasa import SmartDeviceException I don't know what that means. I'm not sure about "upgrade packages, install dev packages" so I'm stuck. What next?
  21. yes to all of the above. It now shows the data in various subfolders. I just need to figure out how to incorporate this in a program. thanks
  22. I'm trying to use my local weather station with my new eisy. I managed to install a node server and it shows on network listing, but it only says the name of the station and station on-line...true. How do I utilize this? Something like using the outside temperature to trigger an event? The only thing in the node frame is query. I've read docs, readmes, googled and found the ployglot v3 page on AW. Logged in to that and it lists a lot of items, but it doesn't tell me how to integrate this to eisy. If I go to add node in AW node server, I get a frame wit name, node address and primary node address. I'm not sure what goes into these blocks. I tried a temp variable in node address but just get bad address. Any simple help would be greatly appreciated. thanks
  23. Update. I got the new PLM in and it seemed to work ok but still was having some issues with devices not updating. In the meantime, I decided to go the the eisy and ordered it as I may be adding a few more SLDs and wanted that capability for the i3 devices. It came in last night and I installed it with the new PLM. Issues with the mobile app, but no problem on PC and restoring. Same issues with the updates on some devices, so I deleted them and reinstalled and put them back in scenes and every one is good for first time is a great while. I don't have any comm problems at the time and will start putting some programs in soon relieving Alexa of most of those chores. thanks for input.
