swamp2
  1. Thanks much. I missed the Products>Catalog of Certified Products links needed before doing a search. Absolutely nil in those manuals, list, links on monitoring power consumption. I dug through all lines for the "Command Classes" and "Configuration Parameters". I'm beginning to think that even though when I linked to this thermostat and a separate "energy meter" Z-wave "device" showed up in my ISY menu, that this is not actually available.
  2. Thanks. Both complete dead ends. Absolutely nothing shows up at Z-Wavealliance.org and there are hits for this model from Honeywell but no manuals or documentation that help.
  3. Bump. Someone has to have figured this out... Thanks.
  4. Some extensive Google-Fu did not yield any manual covering this topic. I called Honeywell and since this is a "Pro" item I was referred to my contractor/installer for support. Well he is a complete idiot, unfortunately... There must be some Pro documentation for this unit somewhere.
  5. Hi, having some difficulty here. This is not working anything like my GE 240V Outdoor Smart Switch for the pool pump (which provides a lot of data right out of the box). All I see in the ISY Admin screen for the Energy Monitor is the attached and it is not dynamic. Is there some manual setup required? Thanks much.
