iannecj
Everything posted by iannecj
  1. Thanks guys...will reset other devices and if I get spurious on again I will look to see if any other programs ran at that time.
  2. I now see in this forum post this is normal:
  3. Not sure how larryllix on either. See my post just now on links table...normal?
  4. Thanks for this great input! I can report no spurious ONs overnight. 1st night in a while. Maybe factory reset or the restore helped? On the list above... I forgot about load sensing. Tested on unit and can confirm it doesn't respond to load ON/OFF but for a second I thought uh oh! Did Raw Text Search as recommneded. Only the email on Home Theater Lights Turn On program was found and no scene uses it. Memberships are blank. The plug in module is on a power strip in a wall alcove behind a roll out AV Rack. At first reading this list I wonderred about this so I checked nearby cables....None could come in contact with on switch or the unit at all even if rack rolled back in (but it hasnt been in since I was testing AV equipment this week and wanted to leave it out if I needed to change something). Question on your 1st item....corrupted link table....can a good unit have this issue? Uh Oh!!! Just did a Show Device Links again....MISCOMPARE is BACK!!!! Since I saw that miscompare when I first posted and restored and factory reset do I already know I have bad unit or is this normal? I have another 2635-222 and just checked it. It also miscompares. Both unit have a google home voice command associated with them. The other is on my shopvac. It never comes on spuriosly...Id know its loud.
  5. Ok Thanks for this...I'll do that now and then see if behavior stops. Been doing in once 2 twice so should be able to tell pretty soon.
  6. By the way, when I compared ISY links to this devices links there were 3 rows....the middle one MIScompared. As such I restored the device and then compared links again to ensure no miscompare. I am starting to wonder if this new device which has never been linked with nother device has some problem.
  7. Thanks did this and no programs save the one I put up in earlier post reference this device.
  8. Yes I do know they came on as when I went into room several hours later I saw them on. Also I do have one program that references this device. It emails me when they have status on.
  9. Thanks for helping me with this! Insteon 2635-222 purchased Nov 2018 Also, I thought entries labeled status was status change but there are other long entties that lookewd like commands to me. for example when I manually command things on and off.
  10. Friends, I have a plug in module controlling a specialty lighting setup in my home theater that's very high power. Because of that I only want it on for short periods. No programs use it. The only means I have built to control the lights is a google home command for on and off via portal. In this log snippet (which is all entries between where I started excerpt and the last entry) you can see us turn them off via voice command at 923 or so. That entry is labeled "web". But then later there is a system status line that says lights are on at around 12:09am after we have gone to bed. There are no command actions in between right? Friends can you give me ideas on what could cause this? Any idea what could be causing this turn on? Scene:MstrClosetLites On Thu 2019/01/10 09:11:42 PM Program Log Grge 2 Lite On 255 Thu 2019/01/10 09:12:25 PM ELK Log Grge 2 Lite Status 100% Thu 2019/01/10 09:12:26 PM System Log mstrclosetsmotion-Sensor Status 0% Thu 2019/01/10 09:21:41 PM System Log Home Theater Lighting Off Thu 2019/01/10 09:23:01 PM Web Log Home Theater Lighting Status 0% Thu 2019/01/10 09:23:01 PM System Log Grge 2 Lite Off 0 Thu 2019/01/10 09:27:32 PM ELK Log Grge 2 Lite Status 0% Thu 2019/01/10 09:27:32 PM System Log Scene:MstrClosetLites Off 0 Thu 2019/01/10 09:29:41 PM Program Log Mstr Clt I Side Status 0% Thu 2019/01/10 09:29:41 PM System Log Mstr Clt C Back Status 0% Thu 2019/01/10 09:29:41 PM System Log Mstr Clt C Side Status 0% Thu 2019/01/10 09:29:41 PM System Log Mstr Clt I Bck Status 0% Thu 2019/01/10 09:29:41 PM System Log MstrClstOvrHeadDim Status 0% Thu 2019/01/10 09:29:41 PM System Log Grge 2 Lite On 255 Thu 2019/01/10 09:31:48 PM ELK Log Grge 2 Lite Status 100% Thu 2019/01/10 09:31:49 PM System Log Grge 2 Lite Off 0 Thu 2019/01/10 09:46:56 PM ELK Log Grge 2 Lite Status 0% Thu 2019/01/10 09:46:56 PM System Log Home Theater Lighting Status 100% Fri 2019/01/11 12:09:31 AM System Log
  11. Can someone point me to the documentation on what the various device tree icons mean? Users guide seems to only explain a couple and I dont see on wiki My current question is what does the icon shown as 2 red spheres connected by a zig zag line mean? And can that indication in fron of my wireless motion sensor be related to why it sends Ons but not Offs to the ISY even though the option "On Commonads Only" is NOT checked. My sincere thanks!
