ImagineAir
Everything posted by ImagineAir
  1. I'm going to work to get all the breakers off except the two that would be needed to keep the ISY and the micro dimmers on and update.
  2. Paul, Two of them have led bulbs, the other has incandescent. I switched the led bulbs to incandescents and I am getting the same load flicker on all three.
  3. ImagineAir posted a topic in ISY994
    Is there a way to have a kpl button be All OFF or ALL ON? I want to have an all on button to turn on all lights on the system. I can create a scene for this but thought it might be easier just to have an ALL command but can't seem to find one to setup in the ISY. On the same note I want to setup a few away scenes that would turn off most lights and fans. For this do I need to setup a scene that lists all devices setting them to off or on, or can I say All Off the turn on light A and B?
  4. I have been using Insteon products for some time, but this is a first home with extensive use and first time with an ISY. I have ended up using 3 of the micro dimmers to control lights where it was the only option. Everything is working, however the lights that are connected to the micro dimmers flicker when there is Insteon Traffic. This can be another room turning a light on/off, or programming scenes on the ISY. The more the light is dimmed, the more noticeable the flicker is. For troubleshooting we have turned off all other breakers in the house and the problem is still exhibited. They do not flicker if no other insteon device is touched.
