toddh
  1. toddh replied to toddh's topic in ISY994
    Backup was the first thing I did this morning when I saw it was up. Thanks again! Todd
  2. toddh replied to toddh's topic in ISY994
    I replaced the power supply with a 12V 2A and the ISY booted right up and is responding normally. If possible it seems faster and more responsive than before, although that may be my imagination given the ISY would be power regulated. I have some spare SD cards around so I may replace it in the future. It should be possible to test the existing card, but I will do that when I have some time. Still in the middle of home improvements. Happy to have my ISY and home automation working! Thank you!!! Todd
  3. toddh replied to toddh's topic in ISY994
    Thanks for the ideas. After I posted the ISY came mostly back up. It was responding to Alexa, I could access the Admin from my laptop(but not my desktop which I had used several days before) and Main looked normal and contained all the devices. But the Programs section was empty. All my Programs were missing. This morning I can access the Admin from my desktop and everything appears normal. The Programs shows all my Schedules. The ISY is performing as expected. I will order another power cube. I think I saw someplace while reading that it is 5V, I am sure I can find the specs here on the forum. Should I replace the SD card, and is it a simple process to do so? Thanmks
  4. My ISY994i has been working fine. I moved it to to another room while doing home improvements and tonight I moved it back to the original location but it is no longer working. It boots and afterwards there are no lights on. It has a static IP and I can ping it and open a web to the IP. I can see Devices and Scenes. However from here it goes wrong. If I go to My Programs it shows "error, Loading: /programs/" . Similar errors when trying to access other menus. Trying to open the admin ioX Finder says "Not Found". I have power cycled several times, moved the unit to another location, swapped out the network cord, tried powering it on with and without the Insteon wall plug(PLM?). What can I do to get my ISY working? Any ideas are welcome. Thanks! Todd
