Adolfo
Everything posted by Adolfo
  1. Yep kind of works like that. I’ll suggest to have in mind that user programmer and user customer needs are different things. For example, as customer you want to have a few tabs with “favorites” as will be easier that have 40 programs on one long list. That tab should have a way to identify it . Like outdoor , a/v or any other thing. As customer the less options the better. Txs -a
  2. In order to let customers use the app is necessary a "Customer Mode" where no changes are available and is password protected. To simplify the user experience I suggest just Programs and Scenes tabs - Scenes could be a group of devices (as now) but also one can create a scene with a single device in an scene. In that way the user just see 2 tabs simplifying navigation. Maybe a 3rd ( Settings with a lited menu as reboot, customer mode and any other thing that the customer could need limited to things that will not modify the functioning or cause intervention of the integrator-vendor. In short, a customer view limiting editing with a password.
  3. What Shelly relay model are you testing ?
  4. Well, at this point I rather use anything non-insteon. The options I'll use are either a raspberry pi GPIOs or a relay connected to them, regardless of what's triggering the raspi. Any ideas? Not sure if I can ran the same raspberry with the GPIO Node though.
  5. What will be the best way of link a relay on-off to isy944. ie : a sensor closes ( or opens) a relay when detects something. Thanks
  6. It was that. Thanks!
  7. Question: After a power outage, Isy reboots. If you run the admin console, You'll see a progressive bar and until it finishes all programs wont be running. Does ISY run that "progressive bar process" time even if you don't login to admin console? And what exactly is it doing? Thanks!
  8. Question....do I need to install this Dorita to find out blid passwrod on a Raspi ? a And then let it be to have the node working?
  9. Really interested in a Ring Node - Ideally to have Motion and / or ring button as separate triggers. Thanks!!!
