phatmatt
Everything posted by phatmatt
  1. Yes you will need to remove the rubber feet to expose threads for the bolt. 3x10mm hex heads is what i designed it for. Also yes on the vibrating. Its an effect. My laptop does the same thing on my fingertips.
  2. Lol. You can figure it out as well as I can. Corona California 92883
  3. I certainly can. Im in corona California. You pay shipping. Ill print it for ya free.
  4. phatmatt replied to phatmatt's topic in Polisy
    Has this migration utility been released?
  5. phatmatt replied to phatmatt's topic in Polisy
    Thanks.
  6. phatmatt posted a topic in Polisy
    Is it possible to use 944i pro backup and restore that to Polisy? Avoid having to start from scratch on new Polisy.
  7. Thanks Mr Bill. I was just thinking duh.. bypass the switch and just keep power to the insteon. Isy will still see the triggers, but since its bypassed, dont do anything except programmatically. I remember seeing a red wire. Ill have to check wiring diagram. Thanks
  8. Thanks. Fast on double tap is an option, but I'm certain other family members wouldn't do the fast on and I would be setting up lights constantly. Im thinking I may just have to ditch the insteon, put in some other kind of switch that doesnt actually cut the power but triggers a scene or automation or something.
  9. Is there a way to disable an insteon dimmer switch? Use it just as a trigger not actually cut power to the circuit. My patio switch works great, but now I've added more lighting and a fan on the patio. I would like to be able to keep the power to the patio circuit on, and manage the lights and fan with sonoff wifi switches. The lighting needs power on all the time to stay connected to the wifi, and the way it is now, when I hit the patio switch the bulbs lose their up address. Any information and/or ideas would be greatly appreciated.
  10. I have a fan I would like to control with a keypadlinc 6 button. I have the fan installed, connected to a Bondbridge nodeserver. It works great from the Bond app. It works great from within isy at the device level. But for the life of me I cannot figure out the scene deal. I read tons of tutorials and threads, but I just dont get it. I can get it to work ONCE great. But if I try to change something after the first test of all the buttons, they dont work. Well, except for the light buttons. They work flawlessly. LOL For example. I create a scene for low, med, high, off. I can turn it on low, turn it on med, turn it on high. cool beans. But after that, say i go from high down to low, the led on the button will follow but the fan will stay on high. any further button presses moves led correctly. but the fan usually stays high. Once in a while it will got down to medium and sometimes to off. never goes back to low. I am surely doing something wrong. please help Also cannot figure out how to export a scene to share here. Best I can do is pictures. The scenes are all basically the same except for the controller and the responder setting (fan speed 1, 2, 3, off. I can post if needed.
  11. Funny you mentioned that. I noticed them going off one at a time, but hadnt looked into that yet. Thanks.
  12. Yep that was it. TYVM
  13. Master Bath Lights - [ID 001E][Parent 0001] If 'Master Bedroom / Bathroom / Matt's Sink' Status is Off Or 'Master Bedroom / Bathroom / Shelli's Sink' Status is Off Or 'Master Bedroom / Closet / Closet Switch' Status is Off Or 'Master Bedroom / Bathroom / Master Bath' Status is Off Then Set 'Master Bedroom / Bathroom / Matt's Sink' Off Set 'Master Bedroom / Bathroom / Shelli's Sink' Off Set 'Master Bedroom / Closet / Closet Switch' Off Set 'Master Bedroom / Bathroom / Master Bath' Off Else - No Actions - (To add one, press 'Action')
  14. Thanks Oberkc. I tried that before asking. That program wont let the lights stay on. If you turn on any of the lights, it turns it right back off. I can say it, LOL, but I cant create it. If any of the lights are on, and either of them changes to off, turn them all off.
  15. This seems like it would be an easy one to do, but Im not getting it. If any of the light switches in the master bath are on, and then any of them change to off, turn them all off.. Do I need to create variable when one goes on? Im lost. Please help
  16. Oh yeah. That's done. like I said, I can see the node server fine in Isy, i just can't or cant figure out how to add the camera nodes. Into isy
  17. Thanks jimbo... yeah I've been thru those threads. The only thing I know I'm doing different is I'm on a vm not a pi. I will try it on a pi if I cant figure it out.
  18. I setup polyglot on a proxmox debian9 vm. Installed Blue iris node server via the store. Blue iris showed up in ISY admin. Cool beans. Now what? I cant figure out how to add nodes for cameras. I go to node server in ISY, go to add a node, and it asks for the node address, and the node controller address. I see those in the polyglot admin panel, but whatever combinations I try comes up with ISY telling me "bad request". I've tried ip addresses, and combinations of what polyglot panel says. Cant figure out what to enter where. Help! I've been trying to work this out for a couple days now. Video searching, forums, walk thrus... I can't figure out what I'm doing wrong. Any help would be greatly appreciated. Thanks
  19. phatmatt posted a topic in ISY994
    Is there a way to disable the Fast on/off feature on an insteon switch or control pad?
