unispeed
  1. i have modbus protocal in in VB and raspi linux if that would help you get started with a server.. Modbus is very common and open source mark
  2. not sure if this got resolved, I had the experienced no heat/cool state statuses once I upgraded to 994i I just went to the stat and manually raised the set point to call for heat and now it is there just thought I would share ..
  3. got my iolinc and it works like a charm I tried ground the unused inputs but could not get a status update with out a query saved the log but it posted ugly with no returns will try again thanks for the help
  4. here ya go thanks ISY-Events-Log.v3.3.10__Thu 2013.09.26 01.00.55 AM.txt
  5. How long ago was the EZIO2X4 purchased and from what company? ABOUT A MONTH AGO FROM SMARTHOME Does the EZIO2X4 have a passthru outlet on the front of the device? NO PASSTHROUGH Is the EZIO2X4 added to the 99i at 3.3.10 or the 994i at 4.0.5? 99i WITH 3.3.10 4.0.5 IS THE USER INTERFACE I HAVE REMOVED ONCE WILL DO IT AGAIN AND KEEP YOU POSTED
  6. restored it twice still acts the same I have input 1 control a light so when I make input 1 on nothing happens when I query the exio the input 1 status come back as on and my linked light turn on remember I have not ran ran/programmed the exio with the serial cable and their little app that I read others talk about... thanks FYI here is a even view when I query the exio then the 2nd pic is when I change the relay state1 which also changes input state1 the pics posted are in reverse order I changes the state 1st then queried it
  7. that's what I figured just ordered one and I will look deeper into the ezio2x4 on a rainy day or season I know it works...... but not quit plug in play maybe I will do so comparisons for the forum to review since I will have both! just wondered if anyone has done that as of yet thanks
  8. the plm is about 1ft for my main breaker box and the ezio is on a branch circuit about 50ft away about 3 repeaters through my house... the EZIO2x4 works flawless and fast for turning the relays on but I have to query to get the input status (I wired the input through the relay1 to simulate the status change) I read you have to run the exio's little app to configure reporting of the input and a other stuff I looked at the diagnostics recommended in the forum still got to figure out what all the messages mean hence my question I was just just looking for a plug and play like a keypad or something....... I might be asking for the impossible but that's why I am asking... (I just wanted to drop it in and program my ISY99i to use it...... Like a newbie would want... looking for the easy way out PS STGE 2 if any developers that want to help write/develop a MODBUS interface I have the MODBUS team ready then we could have a universal PLC interface for those more stringent applications' pm me mark@pteinc.com thanks. Mark
  9. Sorry the confusion it is a isy99i running 3.3.10 ui ud994 v.4.0.5 thanks
  10. Just wondering opinions on which is the most robust device for switched inputs to isy99 I purchased the ezio2x4 installed it and can turn the relay outs off and on I but can only get input status changes updated if I "query it" Just wondered if the iolinc is more robust? if I just need a single input? I don't have the serial cable and other equip for ezio I am running 2412s PLM with v3.1 and isy991 with 3.3.10 and 4.05 ui I am a old newbie who has got lost in the ezio post in chasing unlinks and the like mishaps... brief pros and cons of each or other options please I need it for a domestic hot water heater temp switch to turn a circ pump on KIndor of important but not nuke grade just cold shower grade! thanks mark
  11. unispeed replied to 87boosted's topic in ISY994
    87boosted Have you gone any further with the Modbus protocol? We were able to read and write registers form the ISY-99i development program but it stopped there. Now we just need to get the data mapped to the ISY side..... so close but so far... My company is a Control Systems Itegrator in the industrial world and I believe the ISY would be a great "gateway to the commercial world..if it had Modbus Michel just wants to know ROI and this is where we stopped...... Mark
  12. yes it is the lights connected to the KPL kpl1 a single 100 watt quartz light is under the rating kpl2 6 40 watts candle incandosent are also been working for 13 years with x-10 .....2 years with insteon without a glitch (electrical wise) here is what A SMARTHOME moderator said "No, that's not a communications issue or a device failure. That sounds like an ISY program conflict or an ISY 'restore device' that went bad. Ask over on the manufacturer's forum: http://forum.universal-devices.com" thx Micheal Mark
  13. Just before Christmas I had a 6key KPL start flasing it's load and faint beeping I had 2cfls and 1 incondesent 1st i removed both cfls and it still flashed the sing incond....I installed new 6keypad and it flashes I got me a toggle switch.... now I have a 2nd 8KPL (dif location that flashes with just incons on it airgapped and reset and soon has any button is pressed the load flashes.... I havenot seen any threads talk about loads flashing and no coms with ISY. got any insteon for dummies troublshooting.... I went on a noise hunt cause ISY scense have been irratic...it's about 2years old...know # yet been a long day.....PS I did relocate couple access points before this second KPL started flashing...?? what is odd is all the posts mention led (keys) flashing mine is the "LOAD" the 6 incandesent lights connected to the load wire of the KPL all 3 instances and yes my access points one by my plm i press 4 times and the remote one blinks "bright green" I posted this on SH and they thought maybe somkind of restore went bad?? 3 diff KPLS that all flash the load? about .5 sec on 1 sec off thx MArk
  14. anychance they are still working same batteries? thx Mark
  15. jwagner010, How is your interface with squeeze box going I got a sqBx and isy 99I would you sharfe /sell you code to interface to it or point me in to the right directions for the codes to sqbox? question2 do yhave a sqbox for ea room or something else for squeeze box to direct the music to? #3 is there a manual on the network interface module ? thankyou Makr
