notta3d
  1. Hello, I have had the ISY994I for years, but since everything is setup I don't connect to the console very often. But when I do need to connect I have to be honest I always have a h*** of a time connecting. Firefox and Edge won't connect to the ISY because Java is not enabled so that means I have to use Internet Explorer which we all know is going away. But that is even a pain. I just tried to connect and it asked me to install the Active X Control and then Windows blocked me from doing it because the address is intrusted. This is so frustrating every time I go in I run into this and then I forget how I got in the last time. Am I doing something wrong here? Please tell me there is a HTML 5 version that has eliminated the need for Java??? Am I doing it the old way and things have changed? Any help would be appreciated. Also can you post a link for a new user guide as I might be doing this an old way. Everything is still working though Thanks.
  2. notta3d replied to notta3d's topic in ISY994
    Sounds easy enough. Thanks for the help.
  3. notta3d replied to notta3d's topic in ISY994
    That makes sense. Yes I would rather not like to open ports on my router. I have security camera's that I don't view from the outside because I don't want to open the required ports. 2 questions if you don't mind. Do you have the link to the chirp, chirp thread on how to achieve this? Secondly, is there a forum post on new users and the ISY Portal? I looked and I can't believe that's not pinned at the top. Thanks.
  4. notta3d replied to notta3d's topic in ISY994
    I do. This sounds like the way to go for me. I never signed up for the ISY Portal because to be honest the only instructions I have ever seen were on a YouTube video from like 2016. As matter of fact I just checked under the ISY Portal and the HowTo section and nothing is standing out on how to do the setup. I love the ISY, but I just wish there more how-to tutorials. What is amazing is there are very little YouTube videos on the ISY. I do better following videos No reason to re-invent the wheel when someone else has already done it. Anyway, I appreciate everyone's input and I'll look around to see how to get the ISY Portal up and running since I do think that would be the best way to alert me. Thanks.
  5. notta3d replied to notta3d's topic in ISY994
    Thanks guys. Yes I have an Insteon Open Door Sensor with the ISY. I was concerned about the distance but the sensor is working at 130'. 150 is the max range for a sensor to the ISY correct? Good point about the flashing lights don't help when you're a sleep. Does Insteon make a siren? Unfortunately I don't have any floodlights out back. Any that you guys can recommend that can be used in an ISY program? I was thinking of getting something like the Guardline perimeter system which seems pretty nice. That bad thing is it's a stand alone system and doesn't have any integration with other systems. Thanks.
  6. notta3d posted a topic in ISY994
    I have a shed about 130' from my house that was recently broken into. I just added a door sensor to the shed door and setup an email alert when the door opens so I can hopefully flash a spotlight on them or something to make them run away before they take anything. The only problem is that I don't always look at my phone so I could easily miss it. What is the the recommended program for alerting on something like this? I also have a back door in my garage that I want to do the same thing. Do you flash the lights in the house on and off to alert? Are there any written programs for this? I mainly just have Insteon devices to work with here. Thanks
