mikesommer
Everything posted by mikesommer
  1. Thanks guys will do those two things and hopefully, it takes care of the problem. Does show status of True now.
  2. I noticed that after I looked at your program, will try that, but it doesn't turn it on either, so must be more too it.
  3. Bumbershoot, I'm assuming you are using insteon devices since you are using a scene, this is an older X-10 device.
  4. Not sure if this is the correct place to post this, feel free to move it. I'm new to ISY, and have been able to accomplish a few programs through trial and error. I'm having difficulty getting my porch light which is controlled from an X-10 switch to turn on 30 minutes before sunset, and 30 minutes after sunrise. I have attached the program below, I have tried this numerous ways, and always get the same result, nothing. Any guidance on this matter would be greatly appreciated. Sincerely, Mike Front Porch Light - [ID 0008][Parent 0001][Run At Startup] If From Sunset - 30 minutes To Sunrise + 30 minutes (same day) Then Send X10 'A14/On (3)' Set 'Front Porch Light' On Else Send X10 'A14/Off (11)' Set 'Front Porch Light' Off
