Claas
  1. Just curios if you had any luck integrating these in your ISY?
  2. I actually had one area, the basement, with 17 devices where I had to set it to 3 seconds.
  3. Here's a screenshot of my program. Scene "Check Master Area" is Button D on a KPL6 only. Button D on the KPL6 is the Controller of a Scene turning everything off in the MasterBedArea. Button D comes on when any light in the If is turned on. But doesn't come off after I pressed Button D. Button D is set to Non-Toggle Off.
  4. Any suggestions how to program the following: I have several closets with lights controlled by Insteon Switch On / Off (I rarely see these closets and other people in the household tend to leave these lights on). I have a scene that turns all Closet lights off on a KPL6 on button D, it's non-toggle off, and works fine. Now rather than pressing D every time I leave the house, I would like for D to light up. If Switch A or If Switch B etc is On, then Turn on Button D Else Turn off Button D. I created a Scene with just Button D that the program controls. It works if a Switch is On, then Button D lights, up, I press Button D and the All Closets Off scene runs, but the Button D stays lit. Even so the check program's Else line says turn Button D off. Any suggestions? Thank you
