John McDowell
  1. It is the newer dual band 2457D2 Dual Band model. I think you may be right. I have been doing some testing and it seems like it may be heat related. When I leave it unplugged for a while and then plug it back in it goes for several hours with no problems, then the blinking starts. I was just hoping maybe there was something I was missing other than it starting to fail. As I said in the post, it have had it for a few years, so it has worked well for quite some time, but it is still disappointing that it is failing.
  2. I have a LampLinc module in my system (20 plus devices) that has randomly started to cycle on and off. It is not associated with any scenes other than my ISY-994. (Note, I do have the ISY-994 as part of a HomeAssistant install but have confirmed that no HA commands are being sent to the device. I use the standard ISY HomeAssistant integration). I have performed a factory reset of the device, deleted it from the ISY and re-added it. The cycling has continued. Note, there are no other devices plugged into the outlet with this device. There is a TV, SONOS device and a Wemo smart plug on the same circuit. They were all there prior to noticing the problem. The ISY log file for a cycling event is at the bottom of the post. My question is this: Is this just a failed LampLinc device (it is 5-10 years old) or is there something else I should be looking at). Note, it is the only device in my setup that is doing this. thanks in advance for any assistance/guidance. Wed 11/25/2020 12:56:47 : [ 3A F9 C9 1] DON 0 Wed 11/25/2020 12:56:47 : [D2D EVENT ] Event [3A F9 C9 1] [ST] [255] uom=100 prec=0 Wed 11/25/2020 12:56:47 : [ 3A F9 C9 1] ST 255 (uom=100 prec=0) Wed 11/25/2020 12:56:47 : [INST-SRX ] 02 50 3A.F9.C9 4C.18.71 45 11 01 LTONRR (01) Wed 11/25/2020 12:56:47 : [Std-Cleanup ] 3A.F9.C9-->ISY/PLM Group=1, Max Hops=1, Hops Left=1 Wed 11/25/2020 12:56:47 : [INST-DUP ] Previous message ignored. Wed 11/25/2020 12:56:47 : [INST-SRX ] 02 50 3A.F9.C9 11.01.01 CF 06 00 (00) Wed 11/25/2020 12:56:47 : [Std-Group ] 3A.F9.C9-->11.01.01, Max Hops=3, Hops Left=3 Wed 11/25/2020 12:56:47 : [INST-INFO ] Previous message ignored. Wed 11/25/2020 12:56:48 : [INST-SRX ] 02 50 3A.F9.C9 00.00.01 CF 13 00 LTOFFRR(00) Wed 11/25/2020 12:56:48 : [Std-Group ] 3A.F9.C9-->Group=1, Max Hops=3, Hops Left=3 Wed 11/25/2020 12:56:48 : [D2D EVENT ] Event [3A F9 C9 1] [DOF] [0] uom=0 prec=-1 Wed 11/25/2020 12:56:48 : [ 3A F9 C9 1] DOF 0 Wed 11/25/2020 12:56:48 : [D2D EVENT ] Event [3A F9 C9 1] [ST] [0] uom=100 prec=0 Wed 11/25/2020 12:56:48 : [ 3A F9 C9 1] ST 0 (uom=100 prec=0) Wed 11/25/2020 12:56:48 : [INST-SRX ] 02 50 3A.F9.C9 4C.18.71 45 13 01 LTOFFRR(01) Wed 11/25/2020 12:56:48 : [Std-Cleanup ] 3A.F9.C9-->ISY/PLM Group=1, Max Hops=1, Hops Left=1 Wed 11/25/2020 12:56:48 : [INST-DUP ] Previous message ignored. Wed 11/25/2020 12:56:48 : [INST-SRX ] 02 50 3A.F9.C9 13.01.01 CF 06 00 (00) Wed 11/25/2020 12:56:48 : [Std-Group ] 3A.F9.C9-->13.01.01, Max Hops=3, Hops Left=3 Wed 11/25/2020 12:56:48 : [INST-INFO ] Previous message ignored. Wed 11/25/2020 12:56:49 : [INST-SRX ] 02 50 3A.F9.C9 00.00.01 CF 11 00 LTONRR (00) Wed 11/25/2020 12:56:49 : [Std-Group ] 3A.F9.C9-->Group=1, Max Hops=3, Hops Left=3 Wed 11/25/2020 12:56:49 : [D2D EVENT ] Event [3A F9 C9 1] [DON] [0] uom=0 prec=-1 Wed 11/25/2020 12:56:49 : [ 3A F9 C9 1] DON 0 Wed 11/25/2020 12:56:49 : [D2D EVENT ] Event [3A F9 C9 1] [ST] [255] uom=100 prec=0 Wed 11/25/2020 12:56:49 : [ 3A F9 C9 1] ST 255 (uom=100 prec=0) Wed 11/25/2020 12:56:49 : [INST-SRX ] 02 50 3A.F9.C9 4C.18.71 45 11 01 LTONRR (01) Wed 11/25/2020 12:56:49 : [Std-Cleanup ] 3A.F9.C9-->ISY/PLM Group=1, Max Hops=1, Hops Left=1 Wed 11/25/2020 12:56:49 : [INST-DUP ] Previous message ignored.
