tomas21
Everything posted by tomas21
  1. Resolved Rebooted the eISY a couple times Attempted one last restore of the PG3x backup to the PG3x backup It restored and took me back to login screen All plugins were connected... It asked for one more reboot for eISY for the PG3x to load latest version I take it.. All is well.
  2. My eISY failed its upgrade from 5.8.4 to 6.0.4. Following the support guidance from UDI, I backed up all my eISY data and PG3x data and then performed a manual firmware upgrade with their image file just fine. eISY Firmware update to 6.0.4 successful Restore from eISY backup of 5.8.4 was successful and all insteon, schedules, state config etc came over on the newer 6.0.4 version PG3x restore ... the restore completed successfully but all my plugins show unmanaged What is the best way to get these plugins being managed since restore from PG3x to PG3x with their backup configuration I have restored? Or is there a better process to get PG3x up and running with my PG3x backup?
  3. @Goose66 this still in the backlog to potentially consider?
  4. Anyone willing to take a look at the code on this repo https://github.com/UniversalDevicesInc-PG3/udi-shelly-poly/tree/master and mod it to to support the latest Shelly device, Shelly Plus RGBW PM ? The current repo supports the RGBW2 but it was recently retired and its newer chip version is Shelly Plus RGBW PM which greatly improves performance esp with dimming and speed to dim. https://github.com/UniversalDevicesInc-PG3/udi-shelly-poly
  5. Thanks... ya my use case probably a little unique... I have a 600w 12v transformer... it is automated... but i have 3 branches coming out of the 12v to different lighting areas.... of the 3 branches I wanted to be able to turn off or dim once of the 3 branches independent of the others without getting a 2nd transformer... It seems putting a Shelly RBGW2 or similar in the line will be the solution to try out..
  6. We have some outdoor low voltage non-smart LED lights that I'm trying to find a device I can control with my eISY.... some products have been discontinued.. curious what you all use for RBG and or white only outdoor lv lighting.... ability to turn on/off, some that can dim, etc.. FIBARO Z-Wave Plus RGBW Controller 2, Gen5 (seems to be hard to find in stock) Zooz Z-Wave Plus S2 RGBW Dimmer ZEN31 (discontinued?) Shelly Plus RGBW PM (not sure this is supported with eISY) Curious what solutions you all have come up with for adding control to non-smart lv lights (ability to turn on and off for some, ability to dim for those LED's that support) ..
  7. Curious what is the latest LED bulb & mfg customers are using with the Insteon dimmers that plays nicely, can dim low without flicker, and a hum? Last year seemed like Philips LED line was the preference..
  8. tomas21 replied to Goose66's topic in ratgdo
    Thoughts of something like this.. Just received the v2.53i as well an looking into this converter that has a micro usb on the end so no need to solder anything... wire up to the 8500w battery similar to how ChuckBuilds did and then just plug the micro usb into the v2.53i... Also found a straight version micro usb vs. 90 degree too... trying to determine if one is better than other based on reviews.... there are a ton on Amazon.. curious what others have had success with brand / model wise since most probably come from same source mostly..
  9. I have one Insteon 2-wire 2474DWH switch at the end of a circuit that is a 2-wire with no neutral. I know the 2-wire doesn't work with LED's it can't turn them completely off based on its design but was curious if anyone has success found a resistor bypass solution that would allow the 2-wire insteon to turn off my LED light. There is no neutral in the light switch gang box but there is one in the light box for the LED porch light. Please advise anyone has successfully found a solution and one that wouldn't impact ISY signals. I am willing to try to see if I can use LED's otherwise this will be the only incandescence light in my entire house : )
  10. Running isy MyQ node server from goose on a nas. It can monitor garage door and you can can remotely to open, close set monitors like if after 10p and open for more than 2 hrs issue close or send email etc etc. I haven’t migrated to poly3
  11. Yes I have MyQ app, ISY with MyQ node for garage door. Wasn’t home but came home to open garage door. Looking at MyQ log i see it opened while I was away but the log doesn’t show the unique entry that shows it came from ISY command so as if it came from MyQ or manually. Security cams show no one around at that time.
  12. strange logs show no open cmd
  13. Is there any logs that would show what initiated to open my garage door when no one was home? Trying to figure out how my MyQ garage door randomly opened...
  14. Update: Existing setup: Hunter fan / light combo had GU24 bulb types Installed was 2 CREE Led bulbs that had a E26 to GU24 adapter Fix: I removed the CREE LED bulbs with GU24 adapter and installed FEIT LED bulbs that were GU24 native. No hum with low fan speed when turning light on and off I may buy the Philips warm bulbs to try in the GU24 adapters to see if that does it to determine if it is the Cree bulbs or maybe the GU24 adapter Thanks!
  15. Thanks... these are Cree bulbs but I will see about finding some Phillips models to try out. @MrBillare you referring to these Philips Warm glow bulbs?
  16. @MrBill So your thinking when the fan is running at low speed and the light is turned on or off, there is something unique with these bulbs that may be causing the hum issue to the fan motor? I will look for alternative bulbs to try
  17. We have 3 fanlinc's installed and there is one room that exhibits strange sound for 1 second when the light is turned on or off by the KPL AND the fan is running at low. If the fan is running a high, med, or off the "wum" sound does not happen The fan's on level for low is set to low. Any ideas?
  18. Would be awesome if someone could help write a nodeserver for the Shade Store Wireless hub aka Automate Pulse Hub v2 from Rollease Acmeda Lots of activity for various other automation solution here
