CalPolyME
  1. Please disregard. I needed to use https, http.
  2. I have polyglot v2 running on an rpi. The node severs appear to be running but I cannot access the web interface page anymore. I get the response "This page isn't working". I've tried connecting via Chrome and Safari, and it's the same issue.
  3. I have configured a state variable to act as a switch in GH. I have '0' as off and '1' as on. In the main GH screen it shows up as switch. If I long press the switch icon, it takes me to the device screen. On that screen it shows a dimmer control. I can select a dim value between '0' and '100' using the rotary slider. It will then update the state variable to the dim value I select. When I go into the device setting screen in GH, it is also listed as a switch. This seems like strange behavior. Is this intended?
  4. I will try the reset and restore. Any idea what the "errant signal" would be to turn on some devices, but not all?
  5. I recently added a SwitchLinc Dimmer to control my hall lights. I just experienced an incident when the dimmer was turned on and many other devices in the house turned on as well. None of the devices that turned on were linked to the dimmer. They include a FanLinc, other dimmers, and most concerning, an I/O Linc that caused my garage door to open. This has only happened once since installing the dimmer about 3 weeks ago. Has anyone experienced anything like this before or have any suggestions to fix it?
  6. Yes. I tried it before and after a synchronization. Is there a way to load and older version to confirm?
  7. No luck. I tried 0.101 and the issue persists. Let me know if I can provide any details that may help troubleshoot.
  8. @Javi, I get some sort of java error when I try to access my zwave door lock device in Android version 0.99 (see attached screenshot). After I clear the error dialog box, I have no controls available for the lock device. It only shows the battery level and status. I have version 0.97 on another device, and I don't get the error. Control works fine. I have IOS version 0.51 on another device, and I don't get an error. Control works fine. I want to believe this error is related to the version, but could it be something else?
  9. Thanks @Javi. I appreciate the reply.
  10. Is there a way to hide or disable the admin dashboard? I would like to add the app to my kid's device with a few favorites setup for them to control. I've hidden everything else on the Home page. I would prefer to hide or disable the admin dashboard from them.
  11. Thanks for the welcome. It's unfortunate this is not working properly. I had high hopes.
  12. I am suffering the exact same issue. Have you made any progress on this?
