Me2
  1. Me2 replied to Me2's topic in ELK
    FIXED... Didn't scroll down polyglot config... DUH
  2. Me2 replied to Me2's topic in ELK
    Looking at the Eisy, Main, where the Elks zones are displayed... I have a zone called pantry door. There isn't any status. If I open and close the door nothing changes. So none of my programs using Elk zones are working. If I look at the node(zone) in polygot I don't see any change of status. Only thing that changed is the ELK-M!xep was replaced. The M1XEP (old) had a static address. The new M1xep has a new address. On my old isy-99 I had a ELK tab I would go to to update the ipa of the ELK in the ISY. I am assuming the reason things are screwed up is the IPA. I can't find where to put the new IPA? I know I did it when I first went to the new eisy but can't remember.
  3. My elk-m1xep died and was replaced. Can't see elk zones change when I open/close a zone sensor. Can not figure out where to update/change the lan address of the mixep in the eisy. Guessing it's wrong because it was set static on old m1xep.. Everything has been working great for so long it's like trying to start learning all over again. Sucks to be old....
  4. I added a z-wave dimmer switch to Eisy. It added 5 items (nodes?). Can someone point me to beginner documentation that explains what they are and how to use them? ZY0002_1 Dimmer Switch (which I renamed "powder Room Light Dimmer") ZY0002 SC Basic Assoc 2 ZY0002 SC Basic Assoc 3 ZY0002 Scene Button 1 ZY0002 Scene Button 2 Thanks
  5. Color blind and the print so small, I didn't see. I line that I deleted was the PIR that controls the Powder Room Light (program that was working). I don't care. It's all working now. If it ain't broke, don't fix it... Thank again.
  6. THANK YOU! That fixed it!
  7. Before you say it, I have deleted and reinstalled the program many time in the last few days before giving up and coming here for help.
  8. No change... What bothers me is when I "run then" there is no activity in the "event viewer".
  9. Pantry Light - [ID 0005][Parent 0001] If 'Home / Pantry Door' Physical Status is Open Then Set 'Pantry Light' On Else - No Actions - (To add one, press 'Action')
  10. Pantry Light - [ID 0005][Parent 0001] If 'Home / Pantry Door' Physical Status is Open Then Set 'Pantry Light' On Else - No Actions - (To add one, press 'Action')
  11. last run time, and last finish time field in status is empty.
