jzh
Everything posted by jzh
  1. I'm just afraid of the failure of the PLM and nowhere to get a replacement, can I plug it to my UPS battery for better protection? thanks!
  2. Hi, I have a 2241ZTH and want to adapt to monitor my aquarium's water temperature. I know there was once a cable called Waterproof Temperature Sensor (2433A3) which can act as the temperature probe. But it's discontinued. My question is if i can just buy a 10K olm probe to do it (i.e. 'OCR 1M 5Pcs NTC 10K 3950 Ohm Waterproof Digital Thermal Temperature Sensor Probe' on Amazon) ? Anyone has experience to share? BTW, i'm using ISY994i. thanks James
  3. Thanks for your sharing.
  4. Great ideas, thank you all!
  5. I make a warning when motion sensors reach low battery voltage. Then i know it's about the time to switch battery.
  6. Hi i'm using a lot of insteon leak sensors, they work great. But it can't detect filtered pure water leakage, how do you modify it to make it works? i had thought to lay a thin layer of salt under it thanks
  7. Hi My isy seems to be working normally. The only issue is the power light is always OFF. Do you have the same issue? I bought it about one year ago, how about the device's warranty period? thanks James
  8. jzh replied to smokegrub's topic in ISY994
    i just tested, in 5.x.x the siren is OK
