Steve Andrews
  1. I solved this problem: I replaced the PLM , no change. I had an instance of Home Assistant running so I installed the Insteon integration and plugged it into the PLM. It only found 10 devices so I surmised that the eisy was not linking all of the devices in my network. While staring at the event viewer level 3 I noticed some messages about missing links. I downloaded the event files to a text editor and searched for "LINK-INFO" and found 3 devices with missing links. I removed, relinked, and recreated any effected scenes and the DB:cannot open messages went away. I suspect that any time a scene is called with missing links the DB: messages show up but I fixed all of the offending device before I could verify. I also suspect that the old PLM is weak. The symptom that made me troubleshoot this problem was unexpected behaviors that became worse with time. A reboot would clear them up for a while but new things would crop up with time. I miss my isy. It ran without trouble for a long time and I only replaced it when it went out of support. I understand the UDI is trying to remain relevant as technology moves on but I feel the eisy is not ready for prime time. It still does things that no other devices can do in the Insteon world but I am frustrated by the numerous problems I have had with it.
  2. My eisy event viewer has a message DB: cannot load ./FILES.CONF. 1924B9.REC. If I restore from my last backup it goes away but I replaced a couple of devices since then. Is there a way to just replace the file?
  3. There are no issues with the scene. There is only one responder. I only have problems when it is triggered by a program. I can watch the program instantly change to true but the scene doesn't change for several seconds. I connected to the eisy with SSH and used top to check if a process was using a lot of resources but that isn't the case either.
  4. I got my new PLM and installed it. no difference. Out of frustration a created a scene with only one responder and no controller. I disabled all programs except for one that looked at the status of one button on an 8 button dimmer. It still takes as long as 5 seconds to respond. If I turn the scene on from the admin console with either the run then option in program details or the on button on the scene page it is almost instantaneous. There is something going on inside of the eisy if I use logic to trigger a scene. Any other ideas?
  5. Yes, I ordered the USB. I have a brand new serial but I decided to go with the USB to simplify things. The one I'm using is also USB but it's not dual mode and I was difficult to get the eisy to recognize it. I used SSH to look at the /dev directory and it showed up there but for some reason the admin console PLM status showed it as disconnected. I used a different USB port and it started working. I don't trust it so I'll go ahead and replace it before I get too carried away. Everything works eventually so I can live with it for a few days. Thanks again for your help.
  6. Thank you. I will try recreating the scene but I was hoping I wouldn't have to do that. I have over a hundred scenes. I also ordered another PLM. The one I'm using is old (v.99).
  7. Thanks for the reply. Here is the scene test. All devices fail. I tried restoring each device but no change. <html><font color="red">----- Great Room All Lights On Test Results -----</font></html> <html><font color="red">[Failed]</font> Patio Door C (33 E 9 3)</html> <html><font color="red">[Failed]</font> Foyer Front Door H (29 43 55 8)</html> <html><font color="red">[Failed]</font> Patio Door D (33 E 9 4)</html> <html><font color="red">[Failed]</font> Patio Door E (33 E 9 5)</html> <html><font color="red">[Failed]</font> Ceiling Can Lights (1D C4 8D 1)</html> <html><font color="red">[Failed]</font> Patio Door F (33 E 9 6)</html> <html><font color="red">[Failed]</font> East Wall C (43 9D 8 3)</html> <html><font color="red">[Failed]</font> LampLinc 7 Floor Lamp (2E 6C DE 1)</html> <html><font color="red">[Failed]</font> Kitchen South Wall A (41 DE A6 1)</html> <html><font color="red">[Failed]</font> Kitchen South Wall C (41 DE A6 3)</html> <html><font color="red">[Failed]</font> Fan Linc Light (23 F 95 1)</html> <html><font color="red">[Failed]</font> Foyer Front Door A (29 43 55 1)</html> <html><font color="red">[Failed]</font> Wall Sconces (1D CC DC 1)</html> <html><font color="red">[Failed]</font> Reading Light (1A E6 9A 1)</html> <html><font color="red">[Failed]</font> Ceiling Fan Lights (29 4E 96 1)</html> <html><font color="red">----- Great Room All Lights On Test Results -----</font></html> Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 33 E 9 3 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 33 E 9 4 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 33 E 9 5 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 33 E 9 6 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 29 43 55 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 1D C4 8D 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 29 43 55 8 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 1A E6 9A 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 1D CC DC 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 29 4E 96 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 23 F 95 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 43 9D 8 3 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 2E 6C DE 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 41 DE A6 1 not found Wed 12/27/2023 16:22:48 : [LINK-INFO ] Link for responder 41 DE A6 3 not found Wed 12/27/2023 16:22:48 : [INST-ACK ] 02 62 00.00.23 CF 13 00 06 LTOFFRR(00) Wed 12/27/2023 16:22:48 : [Std MH ] Unexpected Ack imCmd=62 cmd1=LTOFFRR 0x13 Wed 12/27/2023 16:22:49 : [INST-TX-I1 ] 02 62 21 4F 52 0F 0D 00 Wed 12/27/2023 16:22:49 : [INST-ACK ] 02 62 21.4F.52 0F 0D 00 06 (00) Wed 12/27/2023 16:22:58 : [INST-TX-I1 ] 02 62 21 4F 52 0F 0D 00 Wed 12/27/2023 16:22:58 : [INST-ACK ] 02 62 21.4F.52 0F 0D 00 06 (00) Wed 12/27/2023 16:23:04 : [ Time] 16:23:04 0(0) Wed 12/27/2023 16:23:34 : [ Time] 16:23:34 0(0)
  8. I recently purchased an eisy and I am working on migrating from an isy. If I write a simple program which uses a button press to turn on a scene there is a considerable delay before the scene is activated. If I right click and use the run then option from the program details the scene changes immediately. The summary page shows that only that program ran. Any ideas?
