tmlangel
Everything posted by tmlangel
  1. Since 2018 I have been using a Honeywell Ademco VISTA-21IP Control Panel w/Onboard IP Communicator with the add on EyezOn EnvisaLink4 connected via a node server to a ISY994. Worked flawlessly. Can manage through Web, Phone app or UD app. Added UD programs to turn on all lights if there were an alarm and set Thermostats to away schedule when Alarmed Away. Another program to return Thermostats to normal schedule when Disarmed. Migrated to EISY a few weeks ago. Running good so far. Node Servers can now be run on the EISY under PolyGlot making it simpler. Nodeserver plugin: EnvisaLink-HW Note: You may not need the Vista IP model as the EnvisaLink4 connects like keypad and provides the ethernet connection. The Vista IP was used to connect to Honeywell Total Connect Monitoring at one point then disabled. Also EISY and EnvisaLink need to be on the same local LAN network.
