smarthome_newbie
  1. Thanks for all the feedback. After using the remote and depleting the charge a small amount, it now has a solid light when charging. But it starts flashing soon after, which seems to indicate it’s fully charged. Perhaps this is what the old version does?
  2. Thanks for the info. I’ve tried 3 different chargers, one being a regular cell phone charger for iPhone. Not sure what voltage. Remote says v.1.7 1450. Very strange.
  3. I got it off eBay but it looks new.
  4. Hi. The charging LED flashes red while charging. I charged for several hours but it kept flashing. I thought it was supposed to be solid red while charging and go off when charging complete. Not sure if it’s fully charged but it works. Do you think there is an issue with it?
  5. Hi again. My latest controller is an EISY. I went to Plug Ins, Configure in admin console and deleted them there. After that, they are now gone from PG3. I have a couple other questions. I have "ISY Portal" listed as unmanaged in PG3. Is it okay to delete that? Also, I have the Ring node installed, but I have two Front Doors and two Motions showing in admin console, so must still have the Polisy version and EISY both installed. How can I get rid of the inactive one from Polisy? In PG3, Ring shows as connected so it is seeing the EISY version. Thanks!
  6. I upgraded from an ISY to eisy recently. The polisy was never showing in my admin console, which I guess means I was still using ISY for everything, but I did add nodes using Polisy. Now I have nodes added that are showing as unmanaged in Polyglot and it won't let me delete them. I connected Polisy back up to try to delete them, but I can't find the IP under my router page and it doesn't show up in admin console. Any ideas on what to try next?
  7. Just said [All ] Writing 0 bytes to devices. So weird.
  8. I think I was testing something when I initially created the scene. I remember removing the device in the scene completely and then adding it back. I restored the device just now, but still didn't let me delete the scene. The scene is empty now. So strange.
  9. I have a Mac. Does that still apply?
  10. Tried that just now, but still won't delete. It's not hurting anything. Just an annoyance and curiosity why it won't delete.
  11. The name of the scene is "Patio Door Sensor." Yes, I tried to right click and delete, but it says "Request Failed." So strange. Please let me know if you have any other suggestions. Thanks!
  12. Hi. The scene is not in a folder and I just rebooted, but didn't work. Please let me know if you have any other ideas. Thanks!
  13. I was trying to remove a scene that was currently empty. I just added a device to the scene to test to see if that would allow me to delete, but still getting the "request failed" message when trying to delete the scene. I have some devices in folders.
  14. Hi. I am trying to delete a scene in admin console and am getting "request failed." This was for an open/close sensor which I removed because it wasn't working. Any idea how to remove the scene? Thanks!
