Bob A
  1. Bob A posted a topic in eisy
    After the newest upgrade my eisy is running progra.s one hour behind. When I checked the last run times it shows an it ran on the time it was supposed to . So I think it time clock is an hour off . How can I fix this?
  2. Thanks for the suggestions. After looking at the suggestions I found I could have the ELK disable the voice messages when a certain virtual relay was tripped and I could control the relay from the ISY polyglot. This allows you to do things the polyglot can't do itself. It could be modified to perform other things easily. I use this setup to arm and disarm my alarm when other people are sleeping using my Google home to call the program in ISY when other people are sleeping. Here is what I did. In the ELK RP2 under Automation / Rules create two rules (you can use whatever virtual relay you want, but it is best to keep it a lower number for ease of use in the Elk Polyglot) WHENEVER Output 010 (Out 10) STATE IS TURNED OFF THEN ENABLE NON-ALARM VOICE MESSAGES WHENEVER Output 010 (Out 10) STATE IS TURNED ON THEN DISABLE NON-ALARM VOICE MESSAGES In the ISY make 2 programs Program "Nightime" (ARM) set 'Elk Controller/ Output 10' On set ' My Home' set alarm status armed stay Program "Wakeup" (DISARM) set 'Elk Controller/ Output 10' On set ' My Home' set armed status disarmed In the ISY under main tab Elk controller find the relay "Output 10" or whatever number you used and "Set default On" to 15 or so seconds. This will allow you to call the on or off program in the ISY which will toggle the virtual relay on for 15 seconds then off. The relay change disables the Voice and is followed by the arm or disarm command. When the relay times out and returns to normal it triggers the Voice messages back on.
  3. Is there a way to send a "Disable non emergency voice messages" from the ns? I want to be able to arm and/or disarm the system late night when some people are already sleeping. It can be done with the time function in Elk but I only want to silence it when I arm/disarm using the ns.
  4. Monoprice.com has he adapter you need and at about half the price.
  5. Bob A replied to Bob A's topic in UD Portal
    It was staring me right in the face and I didn't see it. Thanks
  6. Bob A posted a topic in UD Portal
    I am trying to delete a spoken from my google home interface and all I can find is a trash can that wants to delete all of my spokens. I only want to remove one and not have to redo all the others. There must be a way but I can't seem to find it. Any help would be appreciated.
