HAO
  1. HAO replied to mserrar's topic in UD Portal
    1. the Z-Wave dongle is not properly seated in it's slot in your ISY Yes, I just checked it out again and got issue number 1, now everything is ok Thanks Bumbershoot very much!
  2. HAO replied to mserrar's topic in UD Portal
    z-ware's menu is in like this
  3. Hello, I have a question please give me advice. I plan to use the honeywell thermostat TH5320R to connect to my ISY via the polyglot node server running on the raspberry, how do I connect the isy to the honeywell device? Should use thermostat wifi or z-ware, if using z-ware, the control distance is how much, is limited in how far? Whoever has used the honeywell thermostat, please give me a suggestion. thanks!
  4. HAO replied to mserrar's topic in UD Portal
    Thanks Bumbershoot very much I have solved the problem thanks to your instructions. but I still have a problem when I upgrade z-ware, the error is as shown below. Please give me suggestions to resolve the issue. I am using firmware 5.0.16C
  5. HAO replied to mserrar's topic in UD Portal
    Hello, let me ask is my error below isy what is wrong? I still connected to the polyglot, but there was no node server, networking and portal tab on my admin console. below is screen image and error log on my isy. Anyone who has already encountered this problem please help! Thanks ISY Error Log.v5.0.16C__Mon 2020.02.17 03.31.27 PM.txt
  6. HAO replied to mserrar's topic in UD Portal
    Hello, I am currently having a problem on my ISY. I am using my isy with the firmware version 5.0.15A and it connects well with the polyglot running on my raspberry and isy portal account, but now I cannot connect to the portal account although the status on the admin console shows online but on the web it's not online and the node server item is no longer visible on the admin console. I later updated to a newer firmware version 5.0.16C but it was no different, I also refer to related topics on the forum but it has not been solved yet. Below is the error log and image on my admin console. please help! Thanks!ISY Error Log.v5.0.16C__Thu 2020.02.13 17.11.50.txt
