guyforte52
  1. It is 4G LTE. https://www.tmonews.com/2019/03/t-mobile-home-internet-setup-router-photos/ So far so good. Using with multiple Fire TVs, several computers, many alexa devices, and the ISY994 controlling my insteon switches. I'll report back in a few weeks. Guy
  2. It was set up as static. I just changed to dhcp and unplugged the power and network cable. I then plugged everything back in and it all worked. Portal is online and my lights are functioning as before. I am glad it ended up being something simple. Thanks for your help Paul. Since everything is working satisfactorily now, I will be cancelling my cable modem and sticking with the TMobile home internet . Guy
  3. Yes, I did try this and it didn't help. I also should add that I am able to connect locally and control my lights, just not remotely through the portal and by extension through alexa. The TMobile router does not have a bridge mode, but I was able to use one of its ethernet ports to connect to my original asus router's ethernet port configured as a WAN. I then reconnected my wired network to the asus router and everything wired and wireless was working through the Asus router except the ISY portal. I went back to the Tmobile router and turned off all security and wireless and every was still working off the asus router, but again the ISY portal remained offline. I used an older router reset to factory settings connected to my still active cable modem, and plugged in my Isy box. The isy portal came right back online. I do want to keep TMobile home internet because of the $50 per month unlimited access, and the decent speed it has, but it needs to be compatible with the ISY portal. I am hoping for a timely solution to the incompatibility with the ISY portal. Guy
  4. I just installed T-Mobile home internet and now my isy portal is offline. Any suggestions?
