timholmesjr
  1. Do I need to configure anything on the UD side? Not sure why it sees 129 devices but only 11 accessories.
  2. It seems that only Insteon devices made it over to the accessories tab. None of my Zwave stuff or Nodeservers are showing up.
  3. I installed Homebridge-ISY and after connecting the ISY I can see evidence on the log window that it is "seeing" all my devices. Unfortunately only about 13 showed up in the accessories tab. Reading though the forum it seems that some devices can be problematic. I can't tell how to exclude or include individual devices/accessories. Any guidance or ideas?
  4. Yes. Everything is on the ISY. I have a GE switch right by the lock, but it may be an older one and it could suffer the same problem if it is a range issue. These two are the farthest from the hub. The outside lights on the other hand are only 20 ft or so, but it is on the other side of the exterior brick....
  5. I have a fair amount of Zwave devices (I am a Vera convert). I would have anticipated the mesh network to be somewhat strong, but I have also been converting to Insteon primarily due to its ability to register instant status changes. I may have unintentionally weakened the network. ISY Firmware - 5.0.16C UI - 5.0.16C Product ISY 994i/IR Pro What repeaters have been successful? I have a love/hate with Aeotec, but when their stuff works its pretty good. They have a Range Extender. Any suggestions?
  6. I recently installed a Yale Assure keypad/handle lock (YRL256-NR-619) added the Zwave module (AYR202-ZW-USA). The lock connected and can be controlled by the ISY/Alexa etc. I did notice last night that the status is intermittent. I got the "ISY can't communicate with ....." error. I also have this on a couple of my Zwave devices. They are still able to be controlled, but they don't update status (even when queried). The status changes when a command is sent, but not when I am just looking to verify the device. Is this a known issue, software compatibility, zwave protocol? With my outdoor lights this is an inconvenience, with the lock it is more problematic. Thoughts?
