thrang
  1. So this device is promoted is having integrated HomeKit support, but I have no idea how to add it to Apple home. I just received the Eisy 2.0 migrated from a 994 everything is fine. I can control it via the UD app, as well as the admin web interface. But I don’t see anything in the UD Mobile app or on the admin interface that tells you how to add this to Apple HomeKit. There is no Apple HomeKit QR code on the device, and no matter number anywhere. The whole point of me buying this was to do so. If this is not possible, then I have to return it. So someone, please let me know
  2. After more trial and error, I got the device issue figured out - for whatever reasons, keeping all devices not hidden showed nothing. I had set HIDDEN as a Device Availability as a default, then expressly INCLUDE filtered items (so far, I've chosen three names Kitchen, Dining Room, Exterior, which are in the names of several devices), and then they appeared. I assume there's something in there that was causing it to chose and prevent all from showing, and perhaps I'll stumble across it as I add more devices. Would be nice if there was a way to load the manifest of all devices, and then you could check off what you wanted to include from a single interface. Still great job on this and thank you For the Ring plug in, I can't seem to get the Doorbell itself to activate a Home notification. That's something else to work on for me...
  3. I also tried installing on Mac OS X instead of the Raspberry PI - same thing.., all is set up but no accessories for the ISY devices. I added a Ring Plug in, and that works - I see the Ring video in the Home app This is my config: bridge": { "name": "Homebridge AEF5", "username": "xxxxxxxxx", "port": 51756, "pin": "xxxxxxxx" }, "accessories": [], "platforms": [ { "name": "Config", "port": 8581, "platform": "config" }, { "name": "ISY", "host": "192.168.0.130", "useHttps": false, "username": "xxxxxx", "password": "xxxxxx", "deviceNaming": { "format": "${location ?? folder} ${spokenName ?? name}" }, "deviceDefaults": { "exclude": false }, "devices": [ { "exclude": false } ], "platform": "ISY" }, { "refreshToken": "xxxxxx", "platform": "Ring" } ] }
  4. I installed Homebridge as described in the second post (though it seems HomeBridge ISY is the latest branch by pmouli from a month or so ago, replacing the version referenced in your 2018 post - https://github.com/pradeepmouli/homebridge-isy-js I configured Homebridge ISY with the credentials to my ISY 9941, and I see a long log list on the main page of Honebridge with my devices, referencing activity ready from the ISY. I dont have device list filtering in the settings... I updated the Config UI X as prompted as well. I can log into the Raspberry Pi no issues, and I added the Homebridge as an accessory to Home (iOS notes it as an unsupported bridge) But in the Home app or Homebridge,, I dont see any devices at all - not sure how to add/see the Insteon devices I have running (about 60 in all) I'm sure I'm an idiot here - any ideas? Thanks
  5. ok, got this mostly worked out - i wasn't using the the correct admins console it seems. I updated the programs, but there are two anomalies... one still shows the green arrow and won't update (status NOT SAVED) Another still shows the yellow icon (NOT LOADED/OUT OF MEMORY) Do I have to re-create these, or is this fixable? Thanks
  6. Upgraded without a hitch, but none of my programs work. I know the instructions say you may need to "update" your programs, but not sure what this means - I went through and re-saved each one, but when I run the "then" option to test the action, nothing. I also create a new program to test, and that doesn't work either. The individual devices work and respond accordingly, and I did write updates to the devices in case that mattered... I searched, as I assume I'm not the only one here with the issue... any advice? Thanks EDIT - when I look at the Status screen, all the programs say NOT LOADED under Activity and OUT OF MEMORY under Status...
