ifeldman
  1. I was finally able to get the Siren to work by using the Start Linking under Link Management (which you mentioned above and I forgot about that function, its been a while), and I assumed you meant to start linking from the module and then use the Add Insteon Device option). Thanks Brian!
  2. Thanks Brian, My Firmware and UI are both listed as 5.0.16. I cleared the Java Cache after the update, and again. I launch the ISY finder from the desktop icon and launch the Admin console from there. I verified the 6 digit ID (tried two of them, both have version 4.0 firmware), tried different locations. Tried with linking and without. I select Link Management, New Insteon Device, Auto Discover, with and without the ID, still cannot get to work. Tried rebooting computer and repeating, still cannot get to link. Do you have any other suggestions? Thanks
  3. I just upgraded from 4.7.3 to 5.0.16. The upgrade seems to be working. The main reason I upgraded was to add support to the Insteon Siren module (2868-222). However, I cant seem to add the module. I use Link Management, New Insteon Device. I do not see the module in the dropdown list for device type. I tried to use the address of the module, but I get no response or error message. What am I doing wrong? Thanks, Ira
