PhoneGuy
  1. I did some searching and can't really find the answer I am looking for. I used to have some Fanlinc devices but went away from them after 2 of them died on me. I moved over to Bond controller for my current fans and have had no issues. I recently moved and my wife decided she likes having bedroom light dimmers. Does the Bond units work as dimmers for the lights using the 6 button wall controls?
  2. A few years back I had Fanlinc controllers on all of my fans. Over time I had a lot of issues with them going bad and would replace them. Eventually I got rid of them and moved over to Bond WiFi fan controllers. My question is, have Fanlinc controllers gotten more stable over the past couple of years or are there still issues with them going bad?
  3. @bchats Where you able to get this resolved? I am getting my new locks in today and hoping to have no issues with connecting. I currently have an older version of Yale locks with no issues.
  4. This can be deleted. Issue I found was the Insteon Support Check Box no checked after migration. I have tried over and over again to migrate from my 700 Zwave usb to the new ZMatter board on my Polisy. Every time I attempt the migration it contiuously goes into the do not make changes, turn devices on or off, progress and after it hits 100% it starts over. I have attempted a reboot in the configuration tab, I have attempted the restart in the configuration tab, I have attempted unplug and re-plug the Polisy with the same outcome. Then I restored back to a working version and attempted to delete all of my ZWave devices and once that was done and working, I attempted to do the migration but the button to just start using the ZMatter board and not migrate ZWave devices. That had the same outcome. Anyone have this happen and know how to get around it? I am fine with deleting my ZWave devices and rebuilding that stuff, however I can't get to a working setup where the progress bar goes away after moving to the ZMatter board.
  5. @dbwarner5 I read your posts and every other post I can find. The system kept updating, hits 100% and starts over. I attempted to do a reboot, same outcome. I then attempted a reboot, same outcome. I then attempted to delete all of the ZWave devices and skip the migration part and still same outcome. Next I restored, 5th or 6th time, had to re-add all my zwave devices with the USB dongle plugged back in and I am back to normal. I have to 5.5.2 firmware and did unplug the USB dongle as the migration says to do. Any thoughts on what next?
  6. @dbwarner5 I have gone the the process and back several times. Once it get to the progress bar of the migration, it gets to 100% and starts over again continues to do that over and over. Is that normal? How long should it take for the migration. I only have 2 locks, 2 switches, and 1 repeater on my build.
  7. Not sure where that it is found, however I stopped and restarted the poly node with no change in the 4 nodes in poly. After your last message I went back into poly and it asked me to link my Nuheat with Poly again so I clicked on the link. I went back into ISY and all 3 Energy nodes are there but still only 2 energy nodes in poly. Either way, looks like it is working as designed. Thank you!
  8. When I look at Polyglot it only shows 4 nodes: Controler, Themostat, and 2 Energy nodes.
  9. I noticed that when you did the update ISY now only shows Energy - Day and Energy - Year, there was a 3rd before, maybe Energy - Month? Was that meant to go away?
  10. Not sure if you have integrated your system with Apple Homekit or not. I don't believe this is an issue with your plugin but maybe you can assist. I am using homebridge-isy-maker and my goal is to pull the temperature from the thermostat to the variable Temperature Sensor hb.My_Thermometer.TemperatureSensor.CurrentTemperature which I can get to pull in ISY, but in the home kit app it is taking the variable in ISY (100 degrees) and thinking that is celius and converting it to ferienhight making it 212 degrees. Any thoughts on this or another way to pull either control of the thermostat or at least the current temp into Apple Homekit?
  11. Definitely resolved my issue. Thank you VERY much for this fix and so quick. I have high and low temp alarms for all my rooms in my house.
  12. The issue I am having is not setting the temp in the "Action" setting, but using the device in the "Condition" setting. for example: If (thermostat) > 100 degrees Then notify (email) to me Else (blank) My previous jerry rigged system aloud that. I like to have temp limit alarms just in case something fails.
  13. EDIT: I got the thermostat today and installed it. For the most part pretty easy install. I set it up in Polyglot Cloud and can see it in my ISY control panel. I can change temps in ISY as well as the Nuheat app on my phone. Issue is when trying to create programs the thermostat part does not show up as a under if status but does show up under the action part. For an example if (thermostat temp) > (particular temp), then send alert email. There are 3 energy monitor features that show up for it but the thermostat temp setting part does not. Any ideas?
  14. For flair and ecobee I had to get authentication keys from their wed sites or the company. As for local compared to web based I only like local because then I’m in 1 poly settings rather than switching between them. how will the new Polisy affect this if any? also thank you very much for the work you are doing on this!
