donblake
  1. John, nice job. Thank you. I've been playing with the ISY-99i for some time now with X-10 devices and have just started using Insteon devices. Through these forums and trial-and-error, I've figured out many of the your tips and tricks but not all. Can you explain why "don't have actions that operate on a scene with controllers"? Currently I have only 2 SwitchLinc devices which are in a single scene - a "virtual circuit". Both are controllers. I do have a program that performs an action on that scene. I do this to have the light turned on when an X-10 motion sensor detects motion or an X-10 RF switch is pressed. So far, this has been working fine. BTW - I'm impressed with the way Insteon works and its reliability. My plan is to replace all my X-10 devices with Insteon over the next few months. Don
  2. I've been running an ISY 99i Pro for some time now but have only been controlling X-10 devices. I finally broke down and purchased some Insteon devices (SwitchLinc Dimmer and SwitchLinc Relays). I had some initial trouble adding a couple of devices. The problem, I believe, was due to the devices being on a different phase than the PLM. When I was finally successful in adding them, they weren't reporting status. What I eventually found was that the PLM had multiple links to the devices. After I cleaned up the PLM links and re-linked the devices, they worked fine. Don
