TimBramer
Everything posted by TimBramer
  1. OK, so I have a bunch of LEDenet strips installed using the Magic Home LEDenet controller: https://wisepick.org/best-outdoor-flood-lights/ Fairly unimpressed at this point. The app doesn't allow you to create scenes for the W, just RGB so I can't set a ramp rate when turning on the WW leds. Perhaps this is just a limitation of hte app itself. So it occurs to me I should have done a bit more due diligence when choosing a solution. Fortunately the RGBW led strips can be run off pretty much any RGBW controller. It's nice to have an app or remote where I can select a custom color quickly. But I also absolutely need the following and NRs aren't going to cut it given how much time I'd spend messing with them to deal with scenes mixed in with other insteon devices. What I need is a solution where I can add an RGBW light strip to an ISY scene with other insteon devices and be able to set the RGBW levels and ramp rates for the that RGBW device in the scene that I've added it to. Just like I can with any other insteon device that is a single channel, but in this case 4 channels per device. Before I go and spend the time to get the polyglot Magic UFO stuff in stalled on my Synology in a docker container, I'd hate to go through the trouble only to discover that I can't mix RGBW lights in basic ISY scenes. Will either the polyglot or z-wave solution allow this? Will both or do neither offer this?
