BDDenver
  1. I had downloaded the Mobileink app without knowing it would not work with the ISY Portal. After that I disabled the Mobillink but still could not connect the ISY to the internet. I folowed all instructions above and in the web to no avail. I noticed theat the protal tab would not show up under configuration tab on the Admin module even though the portal was enabled. Then I disabled the ISY portal, Mobileink and the network module. Rebooted everything (computer, PLM, The ISY and the router). Then enabled the ISY portal module, and the Network Module (NOT Mobilink). All worked again. I believe (but don't know) once the MObilink module is activated it affected the ISY portal or the Network module as the Portal tab woul not show up under configuration until I disabled, rebooted and then enabled the correct modules.
