cpamario
Everything posted by cpamario
  1. I recently migrated from ISY with Agave Mobile to EISY with UD Mobile. All of my devices displayed fine with ISY and Agave Mobile. All of my devices transferred over within the UD Admin Console. When it comes to the UD Mobile, all of my devices display fine except for one which is an Insteon 2450 IO Linc. It does show up in the ISY Portal online and in Alexa. Don't understand why this device won't show up in UD Mobile, even after refreshing UD Mobile. You can see in the attached screenshot how it is present in the UD Admin Console but not in UD Mobile. Any suggestions on what I can try to remedy this?
  2. I am trying to control my Pentair Superflo Variable Speed Pool Pump via Insteon/ISY in order to have better scheduling control over the different speeds the pump provides. In looking at the pool pump's manual, I see that I can connect an external low voltage control system to control each of its 4 speeds (One I/O connection per speed) I was looking at the Insteon 2450 Low Voltage I/O module, but see that it only provides control over one output while I need to have 4 separate outputs. I suppose I could have 4 of these 2450 units in my pool box, but was hoping to just have one device to save space. Is there a device similar to the Insteon 2450 that can provide 4 separate low voltage outputs and interface with ISY? Would the Smartenit' IoT4R be an appropriate solution? https://smartenit.com/product/iot4r/ Any other recommendations for my system?
