Gammai
Everything posted by Gammai
  1. Regarding Geddy's posting ... "If you have a spare device that was never added to a z-wave network, try adding that one first. " The ZWave temp sensor is a new device, and I have several others still deployed in the house.
  2. I checked and ZWave antenna is on USB ZMatter - Etsy device. I removed the Zigbee antenna since I have no such devices. I have support for Zwave checked in the configuration of Admin Console. As shown in attached screen shot there is no "Zwave Information" menu option under "Advanced menu? I have no ZWave devices in the Etsy; I am trying to add the previously connected back into the system. I have a Zwave temp sensor sitting right next to Etsy unit. When I press the button on Temp sensor, its LED comes on and blinks meaning it is looking for the Zwave antennae, but Etsy does not see it. i.e. no window opens indicating it has seen a new device. I have "show when button pressed" option set ON in Zwave configuration options? What should I try next?
  3. I have about 10 Zwave devices in the house. All devices were seen on the ISY 994i device. I know none were deployed to the new Etsy, However I am not able to add any of these devices onto the Etsy; which is in same location as 994i unit. I turned on "detect button Press" option for Zwave devices. But pressing the "button" or holding down the wall switch does not add the device to the Etsy ?? How can I determine if new dual Zwave dongle plugged into one of the USB ports on the Etsy is actually working?
