stef2
  1. I am trying to get a moblinc feature to work with my isy99i PRO: MobiLinc Connect. To do so, I have to buy a module (Mobilinc Connect). However, when I navigate to help, then purchase modules, I am led to a webpage that says: Modules No modules installed for this product. No additional modules available. How can I purchase the needed module? Thanks, Stef
  2. stef2 replied to a post in a topic in ISY994
    Hi! I am trying to get my iIISY99 to see my remotelinc 2 and I followed the above steps but cannot find the remotelinc 2 in the device type pulldown list. Help-about tells me I am using the administrative console version 3.1.11, and I just updated Java to version 6, update 29. I have tried clearing the Java's cache, restarting my computer, but no luck...the remotelinc 2 device does not show up in the device pulldown list. What am I doing wrong...??
  3. stef2 replied to jkraus's topic in ISY994
    I also received my remotelinc 2 today. I am also anxiously waiting for ISY to support it... It will be great to be able to use this small remote the same way I can use an 8 buttons keypad...
  4. The solution to my problem is probably straightforward but I cant seem to figure it out... I have a scene that turns on and off 3 outside lights. The scene has only one controller: the button F on one of my KPL. The scene works very well using the KPL F button, ant the KPL button reflects correctly the scene status. The problem is, if I turn on the load button on the same KPL (the button controls a single light in the house), button F remains on, but then if I turn off the load button while the button F is on, then button F goes off (but the lights it controls outside remain on). I cant understand the link between the load button and the F button. I can`t find any program that could cause the two lights to be linked. And why does the button go off while the lights it controls stay on??? I am clueless. Any idea?
  5. This is great! it works fine now...THANKS! Stephane
  6. I've tried adding the line "and program AmpOff is true" to the AmpOn program. Unfortunately, as soon as the amp is turned off by the AmpOff program, the AmpOff program becomes false (it is only true for a fraction of a second when it is exactly 11:45:00PM) and the AmpOn program cannot turn the amp ON in the morning...Did I miss something?
  7. The problem is, I don't want the amp to turn ON in the morning it it was OFF at bedtime...I just want it to turn back on if it was ON at bedtime...
  8. I have an Denon Amp that is controlled by an Appliance Link. I am trying to write a program that will do the following: If time of the day is 11h45 PM and the amp is ON, Then turn the amp OFF, and then turn it back on automatically at 7h00 AM the next day. (so it stays off during the night). If the amp is OFF, then leave it OFF (unless I turn it on manually). The part that I am unable to do is the part that will turn it back on at 7h00 AM if it is turned OFF by the program at 11h45 PM. My programming skills with the ISY99i are very limited. This is probably easy to do, But I could not figure it out. Can someone please help? Stephane
