alixer
  1. That was basically my conclusion as well but surely there must be a way to force the scene to be written to the ISY right? I don't mind if I have to touch every scene. I just don't want to have to touch every device in every scene. Even add/removing a device from a scene does not "fix" it. The only thing I have found is changing a parameter on every single device in the scene.
  2. Yes, this is the exact doc I followed. It's pretty basic so hard to miss any of the steps. And like I mentioned, the devices have the correct PLM (indicated by the fact that I can control a device from the admin console). It's only the scenes that cannot be controlled from the admin console. In order to get the scene to work correctly I have to adjust every single device in the scene. Also, doing a "restore device" does not fix that device within a scene. Only adding/removing it from the scene or adjusting it's parameters within the scene will fix it.
  3. I have a Polisy running version 5.9.1 and my home is pretty much all Insteon devices. I think there are around 70 switches and outlets. Recently my Serial PLM failed and I had to purchase a new one. I followed the instructions from the docs to install a new PLM including the last step of "Restore Modem". But this step doesn't really seem to be doing what I think it should be doing. My PLM "works" as in it is connected and shows all of my devices in its link table. I can add new scenes and test those scenes and everything works perfectly. However, when I test old scenes all the devices fail (lights do not turn on or off and log simply reports failure). So old scenes do not seem to be linked to the PLM even though the individual devices are. I believe the individual devices are linked because their link tables show the PLM and I can control the individual devices via the admin console. Maybe I am assuming too much? I can fix a scene by simply going into the scene on the admin console and adjusting the "On" parameter of each device and hitting the "Update" button. Or I can delete the scene and recreate it. However this is extremely cumbersome with 70+ devices, dozens of scenes and Echo integrations. I want to avoid doing this manual fix for every single device in every single scene if I can. I tried doing a "Restore PLM" a second time but that didn't help anything. Any ideas how I might force a scene to re-link with the PLM without adjusting every single device within the scene? Thanks
  4. @bpwwer The log file from the plugin appears to indicate that it is using onecall (see log snippet below). I ask because I still can't get the plugin to actually populate with data. My API key is a week or more old now and still not working. 2024-04-22 07:17:00,828 Thread-4 udi_interface DEBUG query:_get_weather_data: request = http://api.openweathermap.org/data/2.5/onecall?exclude=minutely,hourly&lat=38.75&lon=-121.29&units=imperial&appid=<myapikey> ... 2024-04-22 07:17:00,910 Thread-4 udi_interface DEBUG query:_get_weather_data: {'cod': 401, 'message': 'Invalid API key. Please see https://openweathermap.org/faq#error401 for more info.'} 2024-04-22 07:17:00,912 Thread-4 udi_interface ERROR query:query_onecall: Onecall data query failed
  5. Just one more update incase anyone else ever runs into this issue. I had another pair of Insteon switches that I could not get the Fast On/Off to trigger a program just as described in the original post. However these devices were not controllers of any scenes, only responders in scenes. I tried removing the devices from all of the scenes they were in and then re-adding them. This did not fix the Fast On/Off problem. Finally I decided to just create a temporary scene and add both devices to that scene as Controllers. I think removed them and deleted the scene. This fixed my problem.
  6. @paulbates OK so I just kind of accidentally discovered a solution and I'm not sure why it works. I removed the 3 devices I was testing with from the scenes they were in and then re-added them to the scenes. Suddenly the Fast On/Off commands worked and I can see manual clicks in the Event Viewer. It's odd that this worked but doing a "Restore Device" did not work. Also the factory reset of the device did not work. So I went to test this fix on another device in which the Fast Off comnand was not working. This time I only removed the device from the scene in which it was the controller. This was enough to fix my problem. Thanks for taking the time to work with me.
  7. @bpwwer I am trying to migrate from PG2 to PG3 so I am just now creating an Open Weather account (basically this makes me a new user). As a new user I cannot create an API Key that works with 2.5 as far as I can tell. I contacted their support trying to get them to give me an API key that will work with 2.5 and they so far have not been able to help me. They just keep telling me 2.5 is deprecated. So maybe new users cannot use OpenWeatherMap plugin?
  8. Both things work. I can manually press the device and it activates other insteon devices. I can also use the admin console of the isy, select the scene and select "On" and the scene operates as expected. If I manually press the device nothing is shown in the Event Viewer. If I use the admin consol and select the device and select "On" I can see events. The 2 attached screenshots are from sending the "On" command and "Fast On" command respectively from the isy admin console. Manual clicks of the device send nothing to the Event Viewer so nothing attached for that.
  9. @paulbates If I look at the Device Link table for one of the devices that is not working ("not working" meaning Fast On/Off programs not running, and no event showing in Event Viewer BUT scene works fine), I can see my new PLM as the very first address in the link table and there are no references to the old PLM. Doesn't that mean it is properly linked to my PLM?
  10. That is so strange. I would think other things would not work if this were the case. Like the scenes work fine, other programs work fine, everything works fine except fast on/off. I tried restore and factory reset. Neither worked. I'll try just removing the device and re-adding it. Any other ideas other than restoring the device and plm which I have tried both many times?
  11. I've been using the Fast On/Off commands for 6-8 years so I do have a good feel for how fast to click it. Also, if it were the speed of my double click then a simple test would be to switch the "Fast Off" command to "Off" in my program and things would work. I tried this and it did not help.
  12. I agree. And that is my current problem, nothing shows in the Event Viewer when manually operating devices. Do you have Insteon devices? Can you confirm that manual operation of a device will fire an event in the Event Viewer?
  13. Yes I updated my PLM. I tried restore many times. No effect. I even did a factory reset on the MasterBed device. The problem is I don't want a basic scene where all those lights go on/off when I turn on my bedroom lights. I have 4 lights in my master bedroom and I want to be able to turn them all off with a double press of the bedroom switch. But I certainly don't want the bathroom to turn on when I turn my bedroom on. So is there a way for a scene to ONLY respond to the Fast Off command? I used to achieve this with the programs.
  14. Yes the "Then" portion runs fine when run from the admin console. No the last runtime does not change. It feels like the Fast On/Off command never gets to the PLM but how do I diagnose?
  15. I am running IoX on a Polisy with version 5.8.0 I am using Insteon devices that were installed 6-8 years ago if I remember correctly. For a long time I had programs that looked like this: If MasterBed is switched Fast Off Then Set MasterBed Off Set MasterHall Off Set MasterBath Off I had lots of programs like this in various parts of the house. They all used to work great but now they do not. None of them work. A couple of questions: 1) Can I accomplish this same thing in a scene? I couldn't figure out how to make the trigger 'Fast Off' for a scene? 2) How can I diagnose my problem? When I open the Event Viewer and select Level "Device Communication events" and then I go to the switch on my wall and press it I do not see an event in the Event Viewer. If I open the Log from Tools > Log I do not see any device communication in the log either. As far as I know this is the only problem I have in my system. There are probably 50+ Insteon devices with dozens of scenes and programs. Everything works fine except for programs triggered through Fast On/Off commands.
