SSamuels
  1. Thanks everyone for the help. Recreating the program worked. Stew
  2. When the alarm is trigged the program is Green. I will try deleting and recreating. Thanks
  3. Level 3 log ISY-Events-Log.v6.0.4__Wed 2026.02.18 04.17.06 PM.txt The IOLinc's address is 42.4.E3
  4. '12129Td/Alarm/ALARM - Intrucsion-Sensor' is switched On. BTW - This worked about a year ago. Recently the house alarm tripped and I realized the ALL Lights scene was not turning on.
  5. An Insteon IOLinc v.41 is connected to my alarm relay outputs. When the Alarm is tripped, the relay output closes. The IOlink registers the closure of the circuit and Polisy recognizes the switching to 'closed'. I have verified that the AC console reports the IOLinc circuit closure when the alarm is tripped and reports the circuit opening when the alarm is cleared.
  6. Program 'Alarm!!+’ not working: 'Alarm!!+' Program – Enabled is checked and program saved What is supposed to happen: If Insteon sensor switched ON, Set scene 'ALARM_All_Lights' = ON Polisy Log – Sensor is switched ON - see attached Scene ‘ALARM_All_Lights’ does not turn on when sensor is switched on If I manually execute the 'Alarm!!+' ‘Run Then’ the Scene turns on and notifications are sent Ghosts in the machine... What could be wrong? Thanks Stew Progam not working on sensor control - switched to ON 20260218.docx
  7. I had a program that had in the THEN - Run Program <Not6. Specified> Likely I removed/modified the Program that the THEN refers to. By restoring a prior backup (Ver5) I was trying to identify the missing program. However when I attempted to restore a v6.0.0 backup, I received the error message as well. When I attempt to reboot my Polisy I get an Error 'Socket Timeout Error' I did a hard boot (powered down) HELP | ABOUT Both Firmware & UI are v6.0.0
  8. I was able to do a backup of my current ioX The restore file was in the original zip format I attempted to restore both a v5.9.1 and a v6.0.0 - both returned the same error
  9. Firmware: ioX v.6.0.0 (2025-09-19) UI ioX V.6.0.0. (2025-09-19) File --> Restore ioX Exit Malware Bytes Turn off Windows Defender YES to proceed Select backup .zip file Error Failed uploading configuration file [see Restore ioX error message .pdf file] Attempted a backup file created today with same error message. Rebooted Windows - same result Any thoughts are welcomed. Thanks Stew Restore iox error message 20251101.pdf Samuels Restore ioX problem20251101.pdf
  10. Thanks for the response. The earlier install that is identified as 1.0.5 never worked - I suspect because I did not have a Google Device Project. I would like to use the 0.2.5 newer plugin as it does not require the G Device Project. Somehow, whatever I installed from the previous NestSDM is still present and when I delete the installed NestSDM from Polyglot and install the latest NestSDM from the store, it still reports as version 1.0.5 and I receive the authentication error - See video attached. Is the phantom 1.0.5 version somewhere in my Polyglot profile? If so can the admin completely delete and NestSDM from my Polyglot account? Thanks very much Stew update to 0.2.5 NestSDM 20250121.094401.mp4
  11. Update Polyglot reported that NestSDM was ver 1.05 [Beta] Attempted to update to 0.2.5 - still could not authenticate Deleted existing NestSDM and installed ver 0.2.5 in another slot Polyglot verified that now NestSMD ver 0.2.5 was installed Authenticate worked - I Completed the authentication and gave ISY control of my Google account. When I attempted to DISCOVER - Polyglot reported that an attempt to discover was made before the connection to the Google SDM API was established. And, now the version of the NestSDM on Polyglot is once again reporting ver 1.0.5 [Beta] Is the prior version over-riding the 0.2.5 setup? How do I prevent this? Thanks
  12. Polyglot reporting: Current version 1.0.5 [Beta] Status: Connected IoX Version: 5.8.4 Connected When Authenticate is clicked the response is: {"error":"Authentication Error"} Thanks for any help Stew Nest PlugIn authentication response 20250120.pdf
  13. Hi- Thanks for the reply. I am fine sharing these items. I do not know how to located devlist, devfile or the debug.log. Can you help point me in the correct direction?
  14. MQTT was working with Ratgdo (Garage Door Opener) · Updated MQTT to 0.0.39 [Beta] · Stop/Start MQTT · Now I get MQTT Notices o Start-up o Waiting on valid configuration MQTT Controller reports NodeServer Online = TRUE, is not communicating with Ratgdo. Any suggestions appreciated. Thanks
  15. SSamuels started following Goose66
  16. Thank you, everyone for the helpful information. Best Stew
