SteveBL
  1. I'm having the exact same issue with my Elk-M1 on my iphone since the upgrade. I'm also having connection issues.
  2. I am having the same problem after upgrading to 6.0. I can not log on via my PC using my old user name and PW and I'm told to please log on using my portal UN and PW. The actual upgrade went well and UD Mobile is fully functional.
  3. Awesome, thanks!
  4. Can I just delete the "Forcast 0 - 9" nodes? I am not using "Forcast" and have not added it to the PG3 Node server but it still populates 10 "Forcast" nodes, all with no data and reporting in Centigrade not F? For the record, I was an early adopter on Tempest on it's initial Kickstarter four years ago and have now replaced my fourth Tempest. They made me buy one because it was out of warranty by a month. (Not cool). I also do not like the haptic sensors for rain and wind and much prefer a real anemometer and tipping bucket. I'm now looking at some higher end weather stations and not these "toy" stations like Acurite and LeCrosse although the fine people at WeatherFlow have a stellar reputation for professional grade weather monitoring, the Tempest is just quite ready for prime time.
  5. Javi, I too have been getting constant crashes when exiting UD Mobile. This started about two and a half weeks ago I think. I used to report them with brief info about what I was doing but I've never gotten a reply so have stopped reporting, hoping some resolution would be posted. Now I'm adding my voice to the mix. I'm using an iPhone 13 ProMax, 1.1.22, 5.7.0, PG3x 3.2.7 I've also include the latest JetsamEvent file Should I post a ticket? I'm more that ready to do a remote if you'd like. Let me know. Thanks Steve JetsamEvent-2023-09-21-163428.ips
  6. Great! Thanks Jim I don't mind not having duplicate lighting nodes at all. I would just like to get back the ability to access, control and show device status from my Elk Keypads. It's 'eisy' enough to manually add devices to the ElkRP2.
  7. Ok, thanks Bob. I just found it odd that the AC suddenly had another NS listed, there was never an ISY Portal NS listed before and I never installed it, and now there is and its under my Elk NS.
  8. PG3x Version 3.1.22, IoX Version: 5.5.7 After this latest update and a reinstall of PG3x (not sure I should have updated), I now have an extra NS installed under my Elk NS. Elk is on NS1 and I now have an unmanaged NS called "ISY Portal" on NS 3. Is this a PG3x or an ELK NS issue? I connected monitor to the eisy and the last line shows, and has been showing since the last update: sudo[3939] root : account validation failure, is your account locked?:...... I am getting that LOTS of "Event received for a different Subscription: Restart!" error again and being reminded that there upgraded packages to install. I really do like the eisy and what it promises which is why I invested in it, and the Zwave dongle as a backup to Insteon. I do realize that this is new and developing product with lots of work being done by some brilliant people to bring it up to a stable, next-level platform. That being said I'm a little sorry I made the switch to the eisy so quickly after it's birth. I thought is would be everything the 994iPro was and more out of the box but I'm pretty frustrated. I'm so close to going back to my 994i which had worked flawlessly for many years but apparently that is not an option so I'm in for the long-run.
  9. I did that but had to inevitably reboot the eisy. Now the UI and Firmware are both at 5.5.7. However the loX Finder shows my "local" URL as loX and the IP as ISY. Before it showed both as IoX.
  10. I did an update from the AC this morning and I now have a mismatch and the AC crashes after login. The warning is AC v. 5.5.6 an ISY Firmware v.5.5.7
  11. Got it, Thanks! I created a ticket this afternoon.
  12. Yes admin/admin is my AC login at this point until I get things set. Yes the Portal is the first login and it's successful then nothing happens when I use admin/admin to log into the PG3x
  13. I get: Polyglot Version 3x UDI's Node Server Integration Platform for IoX Then I log in to my UDI, then get the PG3x login screen, enter admin/admin and nothing happens and I get the following:
  14. Thanks Dennis, updates were applied. Still no PG3x
